SPIKER
Elite Member
I mow about 4~5 acres on/off till I finish and start all over again & like others I have spare sets of blades that I sharpen & swap out. However I just did BOTH sets at one time as I had not sharpened the old set from last season. I usually do one or two mows in spring as the winter grows rocks or sticks & then I swap them out for sharp set. I agree grass cut will tell when to sharpen & having a sharp set will cut with less power required as well as leave a better cut.
I LOVE the GATOR style blades (dont have them for the NEW mower) as I have not had chance to get out to buy them but when I need a new set that is what I will buy. They last a LOT longer between sharpening and cut is much better as well. I also sharpen my brush hog blade once a year after 2nd cut but only cut the rough stuff a few times a year.
I also have had a set of the hardened tip blades which worked great however sharpening them is hard (requires hard disk not flap wheel) but I mostly use a hard disk anyway as it leaves a longer lasting edge from what I can tell a flap wheel sharpening only last 2 cuttings till it suffers whereas the hard disk can last 5 or so cuttings.
Mark
Mark
