How often do you change anti-freeze on Kubotas?
   / How often do you change anti-freeze on Kubotas? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
How often do you change anti freeze on 25 to 70HP Kubotas. I know the book says 2 years but does the advent of extended life anti-freeze change that? Kubota now has extended life A/F too but I have not seen any.
Also, what kind of anti-freeze do you use? Since it's not a wet sleeved engine, I have used either Deere anti freeze or just the 5 year Prestone XL stuff.
How often do you change and what A/F do you use?
   / How often do you change anti-freeze on Kubotas? #2
Every 3 years, or more if it's in a dusty environment. I use Shell ELC. Love it, I use it in all my vehicles.
I also change the hoses and rad cap every 5 years.
   / How often do you change anti-freeze on Kubotas? #3
5 years or 5000 hrs. Test it and you can extend it even longer, providing you use etl antifreeze.
   / How often do you change anti-freeze on Kubotas? #4
I've used Zerex G-05 in the tractor and Jeep for six years now with no ill effects. I changed the stuff in both last year, after five years. Its listed for heavy duty diesel use. I read somewhere that there is a company making an antifreeze that they rate as "lifetime". Can't remember who and I've never followed up on it. I'd be just a tad bit concerned - nothing lasts a lifetime anymore - - at least not the newer stuff. Its called - - "engineered obsolescence".
   / How often do you change anti-freeze on Kubotas? #5
I just switched mine to Peak Final Charge Global. It is compatible with all types of coolant and does not require a flush and as long as you have at least 70% of it, they say that is as good as 100%.
That is why I switched to it, so I don't have to stock different coolants for all my stuff.
Don't quote me on this, but I think it said it is good for 5000 hours or 8 to 12 when test strips are used.
   / How often do you change anti-freeze on Kubotas? #6
I use Peak Final Charge Global in all my diesels
Could you use Peak Final Charge Global in a 1960's farm truck with metal--copper, brass-- radiator?
   / How often do you change anti-freeze on Kubotas? #10
I also use Zerex G05 in my Kubota’s, mostly for the 5 year service interval. Standard green every 2 years would be a pain.
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
kids dirt bike (A56859)
kids dirt bike...
HUTCHINSON DRAG CHAIN GRAIN ELEVATOR (A52708)
HUTCHINSON DRAG...
2001 CHEVROLET 3500 SERVICE TRUCK (A52708)
2001 CHEVROLET...
