How not to bushhog !!
   / How not to bushhog !! #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Finished mowing 24 acres of CRP ground at one farm and moved seven miles to the next 18 acres to be mowed. The west boundary of this farm is Clarks River and the bottom ground floods about every four years and can easily get out of control if not mowed yearly. My brother in law mowed it last year with a large batwing until he got stuck in the wet area, the wrecker called to get him out got stuck, and a neighbor's four wheel drive tractor finally got them out. So the hillside got mowed but the flat land was badly overgrown with brush and 12'-15' tall trees. This year I am mowing it with a 45-year old Ford 4600 and a brand new BushHog 6' mower. The 7 acres in the flat land had to be mowed in low range 2nd gear instead of the normal 4th gear. So 2-1/2 mph instead of 6mph. Makes for a long day. The rest of the ground is on a hillside with a couple acres being seat clinching steep.
Anyway.
Made the first pass Saturday chopping up 1" to 2" saplings and brush so thick that no grass was growing under. Started making the second pass and I noticed a sapling trunk standing straight with all the limbs and leaves off. So I angled over to chop it off. Leaned over to the right and watched the front axle push it down and waited for the rear tire to catch it before it slipped off the front axle.
I miscalculated badly.
The sapling slipped out from under the front axle and snapped upright catching me right between the eyes on my safety glasses. (Never, NEVER ever mow without them!!) That hurt! I had to stop and get the tears out of my eyes before I could continue. Figured I would have a black eye but didn't. Still sore today. I have been mowing since I was 14-15 years old and I know better. I could have easily lost my left eye and with no center vision in my right I would not be able to drive.
Be warned. Mowing is dangerous even if you have been mowing the same ground for fifty years.
Also the brush is so thick that after 30-45 minutes the radiator gets clogged and the temp starts going up. Being a mile from the nearest house I have to load a generator and air compressor in the truck to blow the radiator out.
Be safe!
RSKY
   / How not to bushhog !! #2
2 days ago, cutting tree with chainsaw, 5" branch came "up" and got me on the nose as i just cut thru it. Of course i was expecting it to go "down."
   / How not to bushhog !! #3
This guy has you all beat:
We have a 6 ft. Square tube and welded wire fence in the front yard, and last Saturday, when I heard some thieving Punks might be bringing their BS out to the country, I wanted to make sure they ran into a little resistance before meeting my Kimber 9mm, so I got an electric fence and ran a single wire along the top of the fence.
Actually, I got the biggest cattle charger Tractor Supply had, made for 12.5 miles of fence. I then used an 8 ft. long ground rod, welded a 1/2 masonry bit to a piece of round rod, and sunk the ground rod 7.5 feet into the limestone. The ground rod is the key, with the more you have in the ground, the better the fence works.
On Wednesday my idiot neighbors hired another idiot to trim all their oak trees, yes in June, so now they will all probably die of oak wilt but that’s a whole other story, and one of the limbs came crashing down on top of my fence leaving the main wire down in the yard. So yesterday I'm mowing the yard with my 5 hp Briggs and Stratton push mower. I knew for a fact that I unplugged the charger so I pushed the mower around the wire and reached down to grab it, to throw it out of the way.
Well my sweet little wife had seen that the fence was unplugged and thought one of the dogs had accidentally done it, so she plugged it back in “for me”....How very thoughtful of her.
Now I'm standing there, I've got the running lawnmower in my right hand and the 1.21 giga-volt fence wire in the other hand. Keep in mind the charger is about the size of a marine battery and has a picture of an upside down cow on fire on the cover.
Time.......stood........still..........
The first thing I notice is my pecker trying to climb up the front side of my body. My ears curled downwards and I could feel the lawnmower ignition firing in the backside of my brain. Every time that Briggs & Stratton rolled over, I could feel the spark in my head. I was literally at one with the engine.
It seems as though the fence charger and damn lawnmower were fighting over who would control my electrical impulses.
Science says you cannot poop, pee, and vomit at the same time. I beg to differ. Not only did I do all three at once, but my bowels emptied 3 different times in less than half of a second. It was a Matrix kind of bowel movement, where time is creeping along and you're all leaned back and BAM BAM BAM you just **** your pants 3 times. It seemed like there were minutes in between but in reality it was so close together it was like exhaust pulses from a HEMI turning 8 grand.
At this point I'm about 30 minutes (maybe 2 seconds) into holding onto the fence wire. My hand is wrapped around the wire palm down so I can't let go. I grew up on ranches so I know all about electric fences ... but Grandpa always had those piece of **** chargers made by International or whoever that were like 9 volts and just kinda tickled.
This one I could not let go of. The 8 foot long ground rod is now accepting signals from me through the solid limestone rock. At this point I'm thinking I'm going to have to just man up and take it, until the lawnmower runs out of gas.
'Damn!,' I think, as I remember I just filled the tank!
Now the lawnmower is starting to run rough. It has settled into a loping run pattern as if it had some kind of big lawnmower race cam in it. Covered in poop, pee, and with my vomit on my chest I think 'Oh God please die .... Pleeeeaze die'. But nooooo, it settles into the rough lumpy cam idle nicely and remains there, like a big bore roller cam engine waiting for the go command from it’s driver’s right foot.
So here I am in the middle of June , 104 degrees, 80% humidity, standing in my own front yard , begging God to kill me. God did not take me that day .... he left me there covered in my own fluids to writhe in the misery my own stupidity had created.
I honestly don't know how I got loose from the wire ....
I woke up laying on the ground hours later. The lawnmower was beside me, out of gas. It was later on in the day and I was sunburned.
There were two large dead grass spots where I had been standing, and then another long skinny dead spot where the wire had laid while I was on the ground still holding on to it. I assume I finally had a seizure and in the resulting thrashing had somehow let go of the wire.
Upon waking from my electrically induced sleep I realized a few things:
1 - Three of my teeth seem to have melted.
2 - I now have cramps in the bottoms of my feet and my right butt cheek (not the left, just the right).
3 - Poop, pee, and vomit when all mixed together, do not smell as bad as you might think.
4 - My left eye will not open.
5 - My right eye will not close.
6 - The lawnmower runs like a sumbitch now. Seriously! I think our little session cleared out some carbon fouling or something, because it was better than new after that.
7 - My nuts are still average size yet they are almost a foot long.
8 - I can turn on the TV in the bedroom by farting while thinking of the number 4 (still don't understand this???).
Yesterday changed my life.
I now have a newfound respect for things.
I appreciate the little things more, and now I will always triple check to make sure the fence is unplugged before I mow.
The good news, is that if someone does try to come over the fence, I can clearly visualize what my security system will do to him, and THAT gives me a warm and fuzzy feeling all over, which will also remind me to triple check before I mow.
   / How not to bushhog !! #5
Ahh... "this guy has you all beat".... I'm guessing you are conveying something you found.
Still... was funny
   / How not to bushhog !! #6
:LOL: 😄🤣😂😂
   / How not to bushhog !! #10
Sounded to me like he was talking about 1-2" 'trunks'. I doubt he'd be using the front end to drive over something a bush hog couldn't cut. I've also never known a bigger tree to 'snap' back up like that when pushed over. But im still young and got a lot of years left to find out. Luckily right now my tractors are too small to try that trick. Id be climbing a 2" tree instead of pushing it over. 😅
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A57024)
Koyker Loader...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
