How much water is used by a washing machine?
   / How much water is used by a washing machine? #1
JohnBoy45
Tennessee
Kubota L2800DT
Hi, How do I find out how much my washing machine uses and toliet, a 15-20 minute shower uses in gallons water. Is there any online water charts?
Terry
Terry
   / How much water is used by a washing machine? #3
Most manufacturers list the amounts used by thier machines; check your manufacturer website.
For the shower, the same thing. Most have flow info, especially the low flow models. Otherwise, turn it on normally, fill a 5gal bucket while timing it. From there you can do the math to see how many gpm it flows.
   / How much water is used by a washing machine? #4
   / How much water is used by a washing machine? #5
If can't nail down the right numbers or want it real close, you can put meter in. The last mechanical meter that I bought was about $60. You could more than likely get a non-industrial version for less money.
   / How much water is used by a washing machine? #6
   / How much water is used by a washing machine? #7
<font color="blue">( ... a 15-20 minute shower uses in gallons water. ) </font>
Hold a bucket underneath your shower head for 15 seconds. Determine how much water you collected (with measuring cups, pitchers, etc.) and multiply that number by 4 to tell you how much you use per minute. You should then be able to figure out the rest from there.
   / How much water is used by a washing machine? #8
   / How much water is used by a washing machine? #9
When we built the new house we put in a Whirlpool "Duet" front load washer and dryer. They are supposed to use less water than a conventional washer. I'll have to dig out the manual and see what the usage is.
John
   / How much water is used by a washing machine? #10
John
Volvo 9.5 Cu Yd Hydraulic Loader Bucket (A50322)
Volvo 9.5 Cu Yd...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
Kubota KX033-4 Midi Excavator (RIDE AND DRIVE) (A50774)
Kubota KX033-4...
RIGID TOOLBOX (A52472)
2014 Ford Escape (A50323)
2014 Ford Escape...
