How much water is used by a washing machine?
   / How much water is used by a washing machine? #1
JohnBoy45
Tennessee
Kubota L2800DT
Hi, How do I find out how much my washing machine uses and toliet, a 15-20 minute shower uses in gallons water. Is there any online water charts?
Terry
Terry
   / How much water is used by a washing machine? #3
Most manufacturers list the amounts used by thier machines; check your manufacturer website.
For the shower, the same thing. Most have flow info, especially the low flow models. Otherwise, turn it on normally, fill a 5gal bucket while timing it. From there you can do the math to see how many gpm it flows.
   / How much water is used by a washing machine? #4
   / How much water is used by a washing machine? #5
If can't nail down the right numbers or want it real close, you can put meter in. The last mechanical meter that I bought was about $60. You could more than likely get a non-industrial version for less money.
   / How much water is used by a washing machine? #6
   / How much water is used by a washing machine? #7
<font color="blue">( ... a 15-20 minute shower uses in gallons water. ) </font>
Hold a bucket underneath your shower head for 15 seconds. Determine how much water you collected (with measuring cups, pitchers, etc.) and multiply that number by 4 to tell you how much you use per minute. You should then be able to figure out the rest from there.
   / How much water is used by a washing machine? #8
   / How much water is used by a washing machine? #9
When we built the new house we put in a Whirlpool "Duet" front load washer and dryer. They are supposed to use less water than a conventional washer. I'll have to dig out the manual and see what the usage is.
John
   / How much water is used by a washing machine? #10
John
INTERNATIONAL 5100 (21) ROW SEEDER (A51243)
INTERNATIONAL 5100...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
Land Honor Quick Attach Articulating Boom Mower (A50514)
Land Honor Quick...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
