How much trouble would it be to switch 4x4 to 2x4 and vice versa.
   / How much trouble would it be to switch 4x4 to 2x4 and vice versa. #1
hcforde
austin, tx
none yet
I have a G244 & G194 Bolens(Iseki) and am considering getting a G272. The G244 has a FEL and I am considering switching the front wheel mechanisms and then also putting the FEL on the G272(which would now effectively be a G274).
Has anyone ever tried something as crazy as this?
   / How much trouble would it be to switch 4x4 to 2x4 and vice versa. #2
It might be easier to just switch the engine. If you do the axle swap you'll need
to swap transmissions also because you will also need the output shaft
from transmission to front diff as well as the 4 wheel drive engagement
lever and 4 wheel drive gear set in transmission.
That makes sense!!
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
