How much tractor do I need
/ How much tractor do I need #41
Yes, we also did a lot of farming with 2WD tractors and combines, but we also left some stuff in the field due to muddy ground. After a couple of really bad years, the transition to 4WD began and now you will have to really look for a 2WD in the fields around here and these guys are not amateurs.
Not only do the 4WD gets the crops out when the 2WD were stuck, the 4WD do not rut the fields as badly. Now in some areas with different soil composition, 2WD work fine.
I don't believe that one design or the other is always better than the other for everything. We use both, but on different properties.
/ How much tractor do I need #42
I agree and still have both a 2wd, gear with R1 tires and 4wd,hydro with R4 tires, need to keep them both to participate in some of the stupid debates on the forum.
I wouldn't let either type lead to a self fulfulling prophecy.
/ How much tractor do I need #43
now if for some reason money is tight you can find alot of clean used 2wd drive tractors super cheap.
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
