how much should it cost to fill tires?
   / how much should it cost to fill tires? #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I got a price of $250 to fill the tires of a mf 1428v. Is that about right?
   / how much should it cost to fill tires? #2
I got a quote for $115 each for the rear tires of my TC24D not too long ago. They would have been filled with a solution of calcium carbonate and water. I chose to buy a weight box instead because that tractor is used on the lawn as well as for loader work.
Last year I paid $80 per tire for foam filling the rear tires of my Cub Cadet garden tractor.
thanks Bob. the price I got sounded high but sounds like it's in the ballpark.
   / how much should it cost to fill tires? #4
The TC24 has fairly small rear tires, if your tractor is a bit bigger it would seem to be right in line with my dealer
   / how much should it cost to fill tires? #5
Filled with what? It does make a difference. Rim Guard, CC, antifreeze?
I had my rear R4's (12.4x16) filled with Rim Guard for $175 total.
   / how much should it cost to fill tires? #6
</font><font color="blue" class="small">( Filled with what? It does make a difference. Rim Guard, CC, antifreeze?
I had my rear R4's (12.4x16) filled with Rim Guard for $175 total. )</font>
To all, be very careful about filling your tires with antifreeze solutions. It is very poisonous and it smells sweet to kids and dogs. If you ever get a leak or break a valve stem, and you have kids or pets, then you have to make sure you keep them away from the area and it must be hosed down COMPLETELY because even a very small amount of antifreeze can kill a large dog.
Obviously the same holds true if you have a radiator leak.
   / how much should it cost to fill tires? #7
</font><font color="blue" class="small">( They would have been filled with a solution of calcium carbonate and water. )</font>
Bob, would they use calcium carbonate, all the tires I've had filled with calcium used calcium chloride and water.
Just curious
Andy
   / how much should it cost to fill tires? #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( They would have been filled with a solution of calcium carbonate and water. )</font>
Just curious
Andy )</font>
Chloride, not carbonate, I was confused when I posted. Carbonate is what is used in some lanterns and is flammable . . . if I remember correctly???
   / how much should it cost to fill tires? #9
Calcium carbonate is also known as limestone, marble or that darn sharp rock.
Mike
   / how much should it cost to fill tires? #10
I am having my front tires foam filled NOW
cost of about $ 1 .00 per pound Unknown how much
the cost will be about $ 50 per tire these are small ones
DougM
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
New Holland 479 Haybine (A50774)
New Holland 479...
Brent 876 Grain Cart (A50774)
Brent 876 Grain...
