how much should it cost to fill tires?
   / how much should it cost to fill tires? #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I got a price of $250 to fill the tires of a mf 1428v. Is that about right?
   / how much should it cost to fill tires? #2
I got a quote for $115 each for the rear tires of my TC24D not too long ago. They would have been filled with a solution of calcium carbonate and water. I chose to buy a weight box instead because that tractor is used on the lawn as well as for loader work.
Last year I paid $80 per tire for foam filling the rear tires of my Cub Cadet garden tractor.
thanks Bob. the price I got sounded high but sounds like it's in the ballpark.
   / how much should it cost to fill tires? #4
The TC24 has fairly small rear tires, if your tractor is a bit bigger it would seem to be right in line with my dealer
   / how much should it cost to fill tires? #5
Filled with what? It does make a difference. Rim Guard, CC, antifreeze?
I had my rear R4's (12.4x16) filled with Rim Guard for $175 total.
   / how much should it cost to fill tires? #6
</font><font color="blue" class="small">( Filled with what? It does make a difference. Rim Guard, CC, antifreeze?
I had my rear R4's (12.4x16) filled with Rim Guard for $175 total. )</font>
To all, be very careful about filling your tires with antifreeze solutions. It is very poisonous and it smells sweet to kids and dogs. If you ever get a leak or break a valve stem, and you have kids or pets, then you have to make sure you keep them away from the area and it must be hosed down COMPLETELY because even a very small amount of antifreeze can kill a large dog.
Obviously the same holds true if you have a radiator leak.
   / how much should it cost to fill tires? #7
</font><font color="blue" class="small">( They would have been filled with a solution of calcium carbonate and water. )</font>
Bob, would they use calcium carbonate, all the tires I've had filled with calcium used calcium chloride and water.
Just curious
Andy
   / how much should it cost to fill tires? #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( They would have been filled with a solution of calcium carbonate and water. )</font>
Just curious
Andy )</font>
Chloride, not carbonate, I was confused when I posted. Carbonate is what is used in some lanterns and is flammable . . . if I remember correctly???
   / how much should it cost to fill tires? #9
Calcium carbonate is also known as limestone, marble or that darn sharp rock.
Mike
   / how much should it cost to fill tires? #10
I am having my front tires foam filled NOW
cost of about $ 1 .00 per pound Unknown how much
the cost will be about $ 50 per tire these are small ones
DougM
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2019 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2019 JLG 2632ES...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
CFG Industrial MX15RX (A50121)
CFG Industrial...
