How much should I charge
/ How much should I charge #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I had a guy approach me about bush hogging some empty lots he owns about 4 times a year. These are all good flat level areas that are commercial for sale. The total acres is about 3.75. I figure he would have to spend about $50 an acre to have them mowed on a weekly basis and we mow her about 30 times per season. I figure it would be worth at least $100 per acre to bush hog. that would save him $1100 PER ACRE PER YEAR. Does that seem fair, to low, or to high?
/ How much should I charge #3
</font><font color="blue" class="small">( Does that seem fair, to low, or to high? )</font>
Seems high to me, but nobody charges by the acre around here. It's generally by the hour meter by the tractor, and goes pretty much in hand with the capability of the equipment. My 45hp 4wd bush hog services get $22/hr around here. A bigger stronger rig gets paid more. Smaller - less. That way you're fairly paid whether the 3.75 acres are full of torturous curves/hills/valleys/rocks/trees/water hazards - or pool table flat and postage stamp square.
//greg//
/ How much should I charge #4
I'd say you're charging 3 to 4 times what he could probably get somebody else to do it for. Why don't you call around and find out?
/ How much should I charge #5
</font><font color="blue" class="small">( I had a guy approach me about bush hogging some empty lots he owns about 4 times a year. These are all good flat level areas that are commercial for sale. The total acres is about 3.75. I figure he would have to spend about $50 an acre to have them mowed on a weekly basis and we mow her about 30 times per season. I figure it would be worth at least $100 per acre to bush hog. that would save him $1100 PER ACRE PER YEAR. Does that seem fair, to low, or to high? )</font>
That's one of the things I do for a living.... Assuming the lots are near each other, and could be mowed at one time, without hauling from lot to lot, You're looking at $150 (at least in the Louisville Kentucky market)
I did 2 lots this afternoon, totalling 5-2/3 acres, for $160. I was NOT the lowest bidder on the job. (low bidder's tractor is broke down) (That was 1-1/2 hour job)
/ How much should I charge #6
I say charge as much as you think he is willing to p /forums/images/graemlins/blush.gifay. Around here septic guys will pay $300 just to get me to show up with a tractor & hoe even if it only takes 20mins
/ How much should I charge #7
I would say about $55 - $65 per HOUR. $100 per acre is a little high unless it would take you at least a hour and 1/2 to cut 1 acre. Judging from your experience try to figure out how long it will take you to cut it all and transport, then make sure you are being paid for that time. If it ends up equaling $100 per acre, I would be surprised.
/ How much should I charge #8
</font><font color="blue" class="small">( I would say about $55 - $65 per HOUR. )</font>
If in fact deere755 will actually be using a JD755, that's an unrealistic price to suggest for bushhogging with 15 PTO hp
$55/65 per hour is for the big boys. The guys around here that get that kind of money are using batwings behind Cat 3 tractors.
//greg//
/ How much should I charge #9
I don't understand why the size of the equipment matters, if the charge is per lot. If I was the landowner I would not care what type of machine does the job, just that the job is done. In the Green Bay area, a coworker was doing lots and charging $50 per lot, two years ago. His caution was to watch for garbage, boards with nails and concrete piles dumped from cement trucks. Also, I would have proper insurance.
/ How much should I charge #10
I would guess a good rule of thumb would be $1 per hour per HP. You have to make at least that just to pay for fuel, maintenance, and keep a few meager bucks for your work. It costs you big to pay for a new tractor up front. Then as the tractor is paid for and getting 3-4 years old, maintenance goes up. So you can't make a windfall even after the tractor has paid for itself.
/ How much should I charge #11
Greg, Are you serious? $22/hr on the tractor's hour meter. Around here that wouldn't even pay for the operator, leaving -0- for depreciation, maint, fuel and profit.
All the lots are with in 3 miles of each other. I appreciate all the input. If anyone else has anything else to add please do so.
/ How much should I charge #13
I pay $50 for 3 acres of mine to be cut. Its a flat rate, he takes a long as he wants and does it whatever day he wants to do it. Does mine 3-4 times a year or when my wife says its to high.
I wouldnt pay by the hour, I want a fixed price going in.
/ How much should I charge #14
Well, if you get it figured out let me know cause I'm trying to decide the same question.....
I was thinking $30 per hour for an 8n/5' shredder set-up mowing some small lots in the area I live. No minimum or loading fee, just $30/hr however short or long in took me.
I had somebody tell me that I shouldn't even consider hiring out with this for less the $40/hr.....then I read on here and other places people charging only $20-25.
So, I basically determined the cost of renting a similar outfit from the local rental place and dividing that number by an average 8 working hours. Small JD with 5' KK goes for $175 per day or 21.85 an hour. I figure the convenience of not having to do it yourself is worth something, so $25-30 is probably what I'll do.
I'll have to see though as this is my first year doing this and I may have it all wrong.... /forums/images/graemlins/confused.gif
/ How much should I charge #15
</font><font color="blue" class="small">( Greg, Are you serious? $22/hr on the tractor's hour meter. Around here that wouldn't even pay for the operator, leaving -0- for depreciation, maint, fuel and profit. )</font>
Well, deere755 is a lot closer to me than to NY. So I don't think "around here" means much to the question at hand - which is how much to charge in central IL. Life is a whole lot more reasonable when you start driving south. I will admit though, that $2.20 diesel has me considering $25/hr.
My 45hp KAMA and a 6' rotary cutter can cut at least 3 acres an hour, depending upon conditions. I burn a little over a gallon of fuel an hour. Using those numbers, charging $100 per acre would be the same as $300+ per hour. At that rate, I guarantee you that I'd never get a single phone call.
I have to admit though, that I like the idea of charging a dollar a horsepower. But I respectfully suggest that it be based upon PTO horsepower. That scale would gross me almost $40/hr. Unfortunately, my closest competition has a 80hp (gross) International with a 6' HD bushhog. Last I heard he's getting $26/hr
//greg//
/ How much should I charge #16
I charge $40/hour (one balked at $50, so I dropped it to $40).
I figure he could get his own tractor and/or rent a cutter, and not come close to what I charged for the 5 hour job.
If some want to do it for less, that is fine. These jobs require trailering the tractor/rotary cutter and I don't charge for that time, only mowing time.
Plenty of work, and I'm not in it for the money and not looking for more of this kind of work.
I figure $20 an hour just for my own time, let alone the time on the tractor and the rotary cutter, which for $20,000 worth of equipment, should bring another $20, minimum.
If it is a friend or someone in need, I will do it for near nothing. If I think they are using me as a reason they don't need to buy their own rig, then the price goes up (I remember the guy who always begged me for a ride to and home from work because I almost drove right by his house , then bragged and talked the whole time about how he saved so much money as he could get by with the one car that his wife needed /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif ).
/ How much should I charge #17
I have not been doing it long but I do commerical shreeding, dirtwork ,tilling, etc. I charge $45/hr or $25/acre. It works out about the same in most cases with my 6 foot shredder. Most clients want a per acre price because they know upfront what it will cost. The per hour scares them as they think you might milk them and make it take longer than necessary or at least that is the impression I have got.
Right now I have a $50 minimum on all work but am thinking of raising it. For example if I mow two acres and charge $50, it takes me about 30 minutes to connect the shredder, connect the trailer, load and chain down the tractor. Then 15 minutes to drive to where I am going, 15 minutes to unload, talke to the people, have them show me things not to hit etc, 1 hour to mow, the 15 minutes to load, chain down, collect money, and 15 minutes to drive home. So a two acres to cut took me 2.5 hrs and I made $50. Take out fuel for tractor and truck I made $40. Works out to $16/hr which ain't much when you consider wear and tear on a $20,000 tractor, truck, and trailer. $45/hr turns in to good money on larger jobs. I think a $75 minimum would be better and who cares if you lose the smaller jobs as there aint no money in them anyway.
If you can get $100/acre jump all over it. Non one around here will pay that.
$22/hr is way too low unless you are charging from the time you start getting ready until when you get home. I charge $45/hr from the time it leaves the trailer until it gets back on.
/ How much should I charge #18
I have only been tilling and bushhogging for two weeks and have already figured out that you have to have a minumum. For me I always ask where they live up front.
Based on where they live I tell them what my minumum would be. I have a $40 dollar minumum for the same reasons bdog mentioned. If they live 20 minutes away I ad another $5 for drive time/gas.
I don't worry about someone that doesn't want to pay that because I am not making enought to justify my time if they don't want to pay it. I usually go through the spiel of gas prices, unloading/loading time and people understand then.
Every area is different for what you can charge and get away with it. Check around with some other guys doing that type of work in your area. Just call their ads and ask them. They don't have to know your the competition! /forums/images/graemlins/wink.gif
/ How much should I charge #19
I read everyone's comments so far. Some of you aren't considering what your own time is worth, the operator of the machine. Your also not consdering the support equipment required to get it there and back home. Your going to need a truck and trailer. They might cost more money then your tractor does! It takes time to hook it all up and load your tractor. Your going to burn gas or diesel in the truck, could be more then your tractor.
A pretty accurate "FAIR" way of charging is $1 per horse power hour for most equipment. Got a 40HP tractor, it would be $40 per working hour. I would also have a 1 hour min per load/unload. So if you have to load it on a trailer to move lots, that lot would be $40, even if it took 30min, assuming you had a 40hp tractor.
The reason I and others believe this way of charging is best is it covers all cost better. A 40 HP tractor cost you more then a 20HP tractor. A 40hp tractor burns more diesel then a 20HP tractor. A 40hp tractor can do more work faster then a 20HP tractor "pull a bigger brush hog and/or go faster".
Sometimes you will have to adjust the $1 per horsepower hour average up or down slightly according to your area, the job or the piece of equipment being used.
Another good way of making sure your price is inline for your area is check to see what a very close piece of equipment can be rented for. If you are only doing a few hours work per day, get their half day rate and divide it by how many hours you could work it (3 or so). Add on diesel and whatever you want to make for your time.
If you aren't doing anything but mowing, then you can come up with a by the acre or square foot charge. Then you can quote a flat fee for that job, if you know the size of the lots. Some people would rather know exactly how much it's going to cost. With mowing that's pretty easy/safe to determine if you know the size and type of land you are mowing.
/ How much should I charge #20
I too am fairly new at this game and have been "playing" with numbers but after getting "nosey" with the competition, I've been charging $80 haul-in and $45 hr. which has been working out OK so far. Haul-in covers wear-n-tear, fuel, loading/unloading etc. Others charge $100 to $125 haul-in and from $55 to $75 hr.
Rental companys will rent you a tractor/mower, you pick it up (wear-n-tear on your pick up etc., your time) and the clock starts ticking from the time you pick it up. No way to get it your self? well, they will gladly deliver it for you and pick it up ------ for a fee! or they will even rent you a trailer to haul it (more money) then there's the "damage" fee (if any), cleaning (if needed) and fuel.
I have people asking me for estimates all the time, but being how that most jobs are the "first" time and that there are no jobs that are on "flat" land with no obstacles (every job is different) the best I can do is "guesstamate". When I do the job, I keep record of how long it took, approx acreage/lot size etc. That way I know the next time I do that job I'll know how long it took also if I come across a simular job that the owner wants a price on, I'll have a better idea but I almost always add at least an hour to it just in case and if I beat that extra hour time, it makes the owner happy cause he's saved $45 ! /forums/images/graemlins/wink.gif
So, over time and experiance you'll be able to adjust your rate according to lot/acreage size.
New Holland 354 Feed Grinder (A64047)
New Holland 354...
Case SV280B (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Kubota MX5400DT (A64047)
2020 Kubota...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
