How much play in your loader control?
/ How much play in your loader control? #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
Couple weeks ago I thought I felt a slight slip in the loader control (joystick) while moving some topsoil. Stopped everything, looked for anything leaking or out of the ordinary but didn't see anything. Went back to working and now notice some small play in the control, about 1/4 inch in every direction. Can't be sure it wasn't there before because I can't remember if it was snug or not. Mind playing tricks on me possibly as I get a little older.
I've used the loader quite a bit since then and nothing is worse and works just as before as far as speed and power. Losing my mind or possibly something to look into?
Kubota B2320
/ How much play in your loader control? #2
We bought a used Massey 1533 and there is a lot of slop in the joystick. People here recommended that a nut or something is loose at the bottom of the control. I have yet to look into it as I don't have the luxury of the tractor being where I live and once I get out to the property, it's "go time." :)
/ How much play in your loader control? #3
There has been an interesting evolution in the way FEL joysticks work.
It used to be that the controls used rods and heim joints that were
exposed to the elements. Now more and more FEL valves use an enclosed
mechanism and push/pull cables to remotely operate the valve from
a comfortable positon next to the right leg.
In the old system, you can keep them from getting sloppy by keeping
the heim joints and pivots lubricated with oil (not WD40!). This
maintenance task is often neglected by the owner since the places
you need to oil are somewhat hidden. Buying new heim joints, rods, and
pivot bushings will renew the controls if they are worn out. I did this for
my last Deere FEL, and the prices for OEM parts were reasonable. If the
JD parts weren't too expensive, other brands should not be too bad either.
The newer style cable-operated remote controlled valves essentially
eliminate the exposure to the elements. I really like how tight the
controls are after years of use and no maintenance.
/ How much play in your loader control? #4
My BX25 FEL valve got sloppy shortly after taking delivery last Jan. Since it was brand new, I called the dealer and they sent a tech out. As soon as he removed the screen under the steering wheel to get at the linkages, a nut fell out. He put it back and snugged it tight and that was that! Felt a little stupid not having checked it first myself. Could be yours just has a loose nut or two on the linkages from the joystick to the valve.
/ How much play in your loader control? #5
Probably starting to get a little wear on it. You are supposed to lube the joints at the valve every 10hrs of use. I haven't been as diligent on this as I should be and I'm getting a fair bit of slop in the joystick as well. I have about 400hrs of commercial use on mine though, so the loader joystick sees A LOT of use.
/ How much play in your loader control? #6
/ How much play in your loader control? #7
On my Kubota B7100 I had to replace three loader control valves due to wear.
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2022 Mack Anthem...
125 GAL TANK (A68842)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2017 Ford F-350 Knapheide Service Truck (A66736)
2017 Ford F-350...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
