How much land do you care, how big is your tractor
   / How much land do you care, how big is your tractor #1
kcook
Platinum Member
MI
Cub Lawn Tractor
How much land do you care, how big is your tractor, HP size.
KC
   / How much land do you care, how big is your tractor #2
KC, I think the only way to answer your question so that it benefits you is to have some idea of your intended use. Frankly I have a M9000 90hp 4wd open air tractor and 350 acres of Texas Hill Country which is 80% rock 15% mule and 5% dirt capable of growing crops. I needed the hp for a lot of very difficult tasks that a lesser powered machine would either have trouble with or just couldn't do period but if all I did was plant and till the 10 or less acres that is flat and fertil enough to grow anything on I could probably get by with a 20hp machine. In addition to planting I do a lot of dirt work, run a hydraulic auger and cart around on my loader arms a 1,000lb hydraulic grapple for clearing brush, cedar and picking up and moving large trees and rocks.
Steve
   / How much land do you care, how big is your tractor #3
I have around 11ac and use a MF-1533. 33hp and around 27hp at the PTO. (pics below)
Not sure what else you would like to know.
   / How much land do you care, how big is your tractor #4
around 600 acres with a M4900
   / How much land do you care, how big is your tractor #5
</font><font color="blue" class="small">( around 600 acres with a M4900 )</font>
Show off, lol... I wish I so wish.
   / How much land do you care, how big is your tractor #6
I have a whopping 2.5 acres of large harwood and gigantic pines and my little 21 hp Kioti has done it's share of hard work. I would like to till the flat spots and seed some grass but right now is all about stump pulling. /forums/images/graemlins/laugh.gif
   / How much land do you care, how big is your tractor #7
I regularly maintain 2, 4, and 5 acres with a CK20HST (21 gross, 15.5 PTO HP), drag tree trunks of huge pines I've cut, bush hog other people's pastures, dig stumps for myself and others, a lot of dirt work with the box blade.
I've continually been amazed at the jobs I'm able to do with such a small tractor. Fortunately, it has a lot of weight for it's size class.
John
   / How much land do you care, how big is your tractor #8
60 acres and a Kubota M6800.
   / How much land do you care, how big is your tractor #9
30 Acres - 50HP SAME' (got a good deal on it...)
49T&C
   / How much land do you care, how big is your tractor #10
10 acres of flat grazing land with 30 almond trees in the middle near the house using a 21hp B7510HST with LA302 FEL (about 17hp at the PTO).
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
Yanmar YT359 (A53317)
2015 Ford Transit 150 Cargo Van (A56858)
2015 Ford Transit...
2025 CFG Industrial MH12RX Mini Excavator (A56857)
2025 CFG...
