Tractor Sizing How much HP do I really need?
   / How much HP do I really need? #71
And a lot depends on the jobs you want to do. I needed to be able to put a 20" diameter log 10' long on my sawmill to saw up for 9' boards. That log weighs about 1500 lbs. I couldn't cut the log shorter to save weight.
But at the same time I can't easily move my cousin-in-laws 90HP cabbed JD through my dense woods.
Or the guy that has to move round bales that weigh a ton. Cutting the bale up is possible but dramatically increases the effort to move the hay.
I agree with Garandman generally but would point out that for the task you mention in moving a good sized log, that loader capacity is more important than horsepower. Because B and L Kubotas are generally built to keep them light for mowing and therefore have relatively light front axles, they tend not to have as high capacity loaders as heavier Kioti and Mahindra tractors of the same horsepower.
Also, you don't need to be able to lift the log to full height so a loader that is rated for only 1400lbs can almost certainly lift a 1500lb log a couple feet off the ground for travel even if the load is a foot or so from the pivot point.
Horsepower isn't everything and folks who keep harping about "you can't have too much horsepower" are often not seeing the whole picture. Many tractors (I'm most familiar with Kioti) have a range of horsepower in the same frame size and typically the 40hp version can lift every bit as much as the 60 horsepower version. The loader and hydraulic pump specs as well as tractor weight and of course intended uses all need to be factored in too. Focusing only on horsepower is a newbie mistake.
I bought the 25 hp Mahindra. I definitely feel I could appreciate some more hp. I have a very steep driveway and the middle range the engine Boggs way down going up that hill. Low range has a lot more power. I still think I made the right choice as the price and simplicity of the non emission engine and I think 25 hp is enough. More would definitely be better.
Any aftermarket tuners available for tractors?
   / How much HP do I really need? #73
Tractor choice does depend on more than engine size. One has to differentiate between pulling, rotating equipment and lifting abilities that will be required. The tractor choice may depend on which is considered most important.
Eg: high HP light tractor for mowing - lower HP heavy framed tractor for loader or backhoe - high HP heavy frame for ground engaging equipment.
After having this a while now I'd definitely say if anyone is reading this post wondering if 25 HP is enough I'd say NO! Unless maybe you have a totally flat piece of property. On the other hand I also can't imagine having a DPF on a light use tractor! I use mine to pick stuff up move it or pull trailers around. I'd never be able to do a proper regen with my small piece of property. To be clear this tractor empty needs to be in low range to climb my driveway. My driveway is a bit steep, but nothing interesting. I think in hindsight I should have searched harder for a good used pre emissions higher HP tractor, but when I was looking there was nothing decent out there.
   / How much HP do I really need? #75
See now I feel differently about this. I have driven home 4 different tractors (all HST)from my local dealer and have a decent hill that I have to go up to get to my place.
A 3550, would not go up the hill in high range, just wouldn't. :shocked:
A 1533, same thing, would not go up the hill in high range. :eek:
A 1526, went up in high range without even slowing down. :thumbsup:
A Max 26XL, went right up, but did slow just a little. ;)
Yes I under stand how to use HST, let off the pedal to get more torque. On the 3550 and 1533 I did just that until they stopped, they simply would not pull the hill in high range. So I guess that the power to weight ratio is much lower on those machines. Took right off in mid range, but no deal in high.
Now I have also brought home a 2540 gear model, that thing was like a little rocket ship. Surprised the heck out of me how peppy it was. :cool:
Ultimately it comes down to what you want, are willing to pay for and or willing to compromise on.
All choices that we all have to make. ;)
I'm surprised to hear of your results, the Max 26XL is lighter and has the same engine as the 1526! The 1533 is approximately the same size as the 1526 and has much more HP so should smoke the 1526 on a hill climb! This seems to be a case of common sense will not be tolerated!
My dealer had a nice level piece of property, so I couldn't get a feel for it on the test drive. Honestly as a first time buyer I had no idea what to really look for on the test drive. now with all of my experience, I would shop differently.
Mine seems to run perfectly, I have no reason to think there is any problem with the engine, but even dead empty no wheel weights, no back hoe, no implement or trailer. Even with a running start it absolutely will not climb my driveway in high range (Nice smooth paved driveway). In mid range it slows way down and feels like the engine is really struggling. Perhaps there is something wrong with mine?
   / How much HP do I really need? #77
My Yamnar YM 1700 had 20 HP at the engine and 17 at the PTO...
It was a light weight geared tractor and with loaded rears weighed 1800#...
It had no problem at all pulling a 5 foot rear finish mower...
Power to weight ratio was 90# per HP...
My New Holland 1720 weighed 3300# loaded and with the FEL was around 4000#...
It was rated at 28 HP and 23.5 at the PTO...
Power to weight ratio 143# per HP...
The 1720 would pull my 6' Woods RFM fine but in higher gears and faster speeds felt more labored than the Yanmar...
My Workmaster is north of 7K with the FEL and at 53 HP has a power to weight ratio of 132# per HP...
It does not labor at all pulling the 6' RFM...
On the road in high gear with the Brown 472 attached it will run in high gear but on steep inclines will load up a little...
Where am I going with all of this?
Power to weight ratio plays a significant part in how fast a tractor responds to throttle input...
True story...
My grandfather bought a new John Deere B in the 40's...
They were hard to get due to the war...
He was so proud of that tractor that when he got it he put it in the front yard for everybody to see...
Those old B's were rated around 12 HP at the draw bar at around 1K RPM's...
The Deere dealer at that time would turn the tractors down to 800 RPM's...
He believed that it would increase the engine life...
The first time my grandfather tried to pull the hill from his house with the combine the little B did not make it...
He was spittin mad...
My father turned it up and then the little B could pull the combine up the hill...
Wish I could have seen that episode...
   / How much HP do I really need? #78
As far as the results, the Max 26XL has different size tires, is a different weight and most likely has a different gear ratio.
For the 1533, over 700lbs heavier than the 1526.
When just looking, easy to over look these things. ;)
   / How much HP do I really need? #79
The 1533 does have bigger tires, is heavier and if I remember correctly is wider than the 1526.
I did the math awhile back on this same discussion, people claimed the 1526 has a better power to weight ratio, I can't remember what it was exactly but the 1533 was about even and the 1538 was better weight to power wise.
But many guys have said the 1526 climbs hills better.
But my 4320 JD has 48hp and it VERY quickly bogs down in high gear if you push the peddle too fast, it needs to be rolling before you can push the peddle down. It's like starting a manual car in 4th gear, lots of engine and slow starts.
But I wouldn't be at all concerned with a tractor that can't climb a hill in high gear, that's not what high gear is made for.
I bought my tractor to do work and save my back not race up hills in high gear.
I personally would never attempt to climb a steep hill in high, I would gear down to mid range and not over stress the tractor.
Hi Broke farmer John,
Thanks for the reply, but I do strongly disagree with that statement. High gear is for traveling, traveling includes hills. if you want to drive over the road to another property you need to be in high gear. If it can't climb a hill you can't drive over the road. Even at max speed it's still a slow moving obstacle on the road, forget low range. I hoped to be able to drive this over to my brother in laws house less than 1 mile away, but no way with this thing. I think you guys are imaging some mountain I'm trying to climb, it's steep, but not that bad. It's nothing out of the ordinary and this tractor feels over stressed in mid range dead empty.
OK, but aside the hills and Living in New England this is hard to do. This winter my truck got stuck while snow plowing so I pulled it out with the tractor. The tractor was on level, plowed, but still wet slippery pavement in low range (no impliment or additional weight) trying to pull out the truck. On slippery pavement in low range with only 1 front and 1 rear drive wheel since my diff flock does not work. The tractor would stall or nearly stall trying to pull out the truck meaning even in low range this tractor on wet snowy pavement this tractor has more traction than power. It did finally get the job done, but this tractor is clearly under powered! As far as I'm concerned, you should never stall in low gear, the tires should spin first, ESPECIALLY in the SNOW! I'm also used to having lots of power, from my 73 Camaro, 5.7 Hemi Jeep, 7.3 Turbo diesel F350. Even my log splitter has a 300CI 6 cylinder engine, so perhaps My idea of enough power does not align with everyone.
All of that being said, I can totally deal with these limitations and I love having the tractor. I think it's the perfect size for my needs. Heavy enough to have some decent lift, but still super maneuverable for a small piece of property like mine. Just add a turbo and it'd be great! I would love to try a L2501 on my driveway or perhaps I don't want to!
UNUSED JCT HYD BACKHOE DIGGER ARM (A57193)
UNUSED JCT HYD...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2006 JOHN DEERE CT322 SKID STEER (A52707)
2006 JOHN DEERE...
2023 John Deere 333G Track Loader (A53485)
2023 John Deere...
UNUSED RAYTREE RMBD72 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
