Tractor Sizing How much HP do I really need?
   / How much HP do I really need? #101
My New Holland 1720 was geared and at 28 HP would load up in the higher gears when traveling at any speed on the road. That was in high range in either 3rd or 4th which I consider road gears. At 28 HP and 3300# loaded it was doing all it could do based on it's small engine. Your Mahindra is doing all it can do with it's weight and HP rating. Go to a lower range.
I think you are missing the point(s). The HST transmission is not like a car transmission. Tractors are not cars. They are not designed for high speed travel on roads. And, you are comparing a 4000lb ?200+hp Jeep 4wd to a 25hp small frame tractor???? Maybe you should have done some homework before making a purchase.
Island Tractor, Your correct, I should have done more research. My fault! As a first time tractor buyer there are so many things I did not consider. Until you get some real seat time many things you don't even know to ask. The high range lack of power is a example of the weak engine. To me the real problem is the low range issue. My example of pulling my truck out of the snow I was stalling the tractor in low range on wet snowy pavement without a function diff lock. IMO in low range stalling the engine before loosing traction is simply not enough power. Especially in the snow! Without a functioning diff lock!! I don't see how anyone can argue that.
   / How much HP do I really need? #103
Is there any chance that you could trade up a size or 2 on the tractor? and also possibly (try) a manual with a shuttle shift?
If I read this right this is a virtually new , low hour machine under warranty? with a non functional diff lock.
Maybe talk to the dealer-if bought there and inform him of your frustration and disappointment in the performance power wise?
Living with a new tractor that is not up to your expectations is going to get old and possibly be a source of irritation every time you have to drive up that hill. I guess it comes down to whether getting used to a lower range for the hill is something you can deal with. (Or not)
I know (the Fred) had a problem something similar to this, Although His (solution) involved some radical surgery...
I know (Fred) had a problem something similar to this, Although His solution involved some radical surgery...
I did just last night fix my Diff Lock, thanks to help from Dave from Dave Dave's Tractor, Inc. on another thread. As for up sizing, this tractor is physically the perfect size for me and I had enough trouble justifying this big of a purchase. On top of being afraid of the new emissions engines. Even my truck is a 2003 7.3L the last of the pre-emissions diesel trucks. I'll just have to learn to live within the limitations and/or figure out how to turn the power up on this one.
   / How much HP do I really need? #105
that's good news,
Yeah Dave is one of the most helpful dealers and people on this site.
that's good news,
I'd buy my next tractor from him except for the the fact he's on the wrong coast!
   / How much HP do I really need? #107
Roger, your tractor is working normally. Tractors are heavy and don't have a lot of power. Your 1533 weighs about as much as a mid sized car but instead of 200 hp or more it's got 25. CUTs aren't made to go up steel hills in high gear. My 7100 would barely make it up my steep 15% driveway in high range (of two) with the HST pedal barely cracked. It was really laboring to do it. My Branson won't do it in high range (of three) at all. It's high range is higher than the 7100's was. That high range is for road transits on flat or gently rolling hills. I don't have any of that. I've used it on the one 200 ft long section of flat road I have, just to make sure it works.
Your tractor does have a lot of pulling power. The weight that makes it slow up hills also gives it traction in the dirt. The engine does not have a lot of power but the gearing is low. If you're doing pulling in situations that the tractor was designed for it will do better than the pickup. Like pulling a plow, or logs out of the woods. But it's not going to haul a trailer at 45 mph up a highway hill like the pickup can.
   / How much HP do I really need? #108
Someone's on the wrong coast! :)
I remember the first HST I delivered years ago. The guy had a really step driveway. So I pressed the pedal down further and further. And I went slower and slower. As many have mentioned, that is like shifting up a gear, not shifting down. Fortunately I got my wits about me and let up on the HST pedal and pulled the throttle all the way back and up the hill I went, but not at 10 MPH. On most HST tractors, high range is for travel and not for much work, and going up a hill is work to some extent.
Let's say your tractor is 3200 lbs and 26 HP. You have 123 lbs to lug around with each HP. Take a new diesel pickup and let's say it weighs 7000 lbs and has 400 hp. Each HP has to move 17 lbs. So it is all about gears. We can't really compare a tractor to a truck.
However, your low speed issue seems like it should be looked at. If you were on the correct coast, I'd put your tractor on my dyno and see if it is putting out proper power first. If so and if it really did seems to lack power to the wheels, we would check the HST pressure ports to make sure the HST was working properly. To have a bad one is incredibly rare.
I hate to say this after all of your kind words, but I think some of this is getting used to how an HST works. Use the lowest range that will work for the task at hand, and within the range the more "pedal" the higher "gear" you are in, therefor the least torque available and the best chance to stall. Of course we can't get much done at 1 mph, so I understand there are practical limitations.
Thanks again for the kind words, and give that tractor a little more work with the concept in mind of how an HST works and report back please.
My John Deere LX255 Lawn tractor seems to have a really nice feature built into the hydro. I've towed super heavy loads with this little deere up that same driveway. On the deere you could mash the pedal to the floor and when the hill was encountered, the tractor would slow down, but still climb the hill. It appears there is some governor on the hydro swash plate that automatically "gears down" based on load regardless of the pedal position. On the Deere max pedal always delivered max power and max speed possible given the load. Never would lifting the pedal help. It would never ever stall. I've pulled such heavy trailers up that driveway that sometimes the tires would just break loose on dry pavement halfway up, but it would never stall. Clearly I need to learn how to lift as this tractor does not have this magic feature.
As for actually testing mine on a dyno, would an automotive dyno work? I know some race shops near by with dynos from my racing days decades ago. I would love to prove this one way or another.
   / How much HP do I really need? #110
I have no idea how a chassis dyno would compute with a tractor on the rollers. But it would make for a good photo op. Most all tractors dealers that sell and repair a decent volume of tractors will have a PTO dyno. Without it, there is too much subjectiveness. What feels gutless to one guy is a hotrod to another.
I suspect, based on the fact that we have sold 100's of the 1526/3016 tractors, that your power is ok and your HST is ok. The only time we see complaints on power with this model are when we sell a TLB and load the tires and put it up at high elevation. Now we are getting pretty heavy and have less air and going up hills in high range is not going to happen with that combo. Combine that with a new HST user and his first week or two can be disappointing until he learns to use medium range and to understand the tractors limitations.
Racing days in the past? It's not unheard of for a guy to put a turbo on a small diesel engine. But you then become your own warranty center, if you know what I mean.
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
10' Feed Bunk (A50515)
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
