How much does a load of fill dirt cost typically?
   / How much does a load of fill dirt cost typically? #51
   / How much does a load of fill dirt cost typically? #52
When I went and got them I didn't know what they were called either, I just knew what I wanted. When I read your post I researched them and found they were called several things, Bin Blocks, Mafia Blocks, Jersey blocks, heavy bast***s, etc.
   / How much does a load of fill dirt cost typically? #53
This is the back corner of my berm and shows how I constructed it. About 7.5'. That's my pistol one and that [ shaped construction let me pile the dirt pretty high without needing excessive amount to reach that height and still be moderately thick at top.
I did my rifle one the same way, but went a little taller since it's @ 300 yds. I used PT 2x4 instead of 4x4 for it. Worked well, just took longer to put together and required a lot more vertical support pieces. The sides are a little wavy since the 2x4 aren't as strong and it is wider overall, but still let me pile up dirt pretty high w/o need for excessive amount of dirt.
I have to bring in fill dirt ($$$) for projects like this since I can't dig it from my land. So the extra cost of the wood support structure is offset by bringing in ~1/4 the truckloads of dirt.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
2005 Ford F-350 4x4 Dually Truck, VIN # 1FTWW33P35EC55643 (A54865)
2005 Ford F-350...
UNUSED JCT 84" HYD DOZER BLADE (A54757)
UNUSED JCT 84" HYD...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
