How much does a 4610SU weigh?
   / How much does a 4610SU weigh? #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
Does anyone know how much a Ford-New Holland 4610SU weighs? I looked it up on tractor data and they say a 4610 weighs 5000 pounds but has no weight for the 4610SU which I think is lighter.
The tires are not loaded and there is no other ballast.
Also, will it fit on a 6' wide trailer? They have no data on the width.
I am planning on buying one and need this info to determine how to get it home.
   / How much does a 4610SU weigh? #2
Depending on tire size, fitting that on a 6' wide trailer will be tight, or it probably won't fit. You may be able to bring the wheels in as far as possible but I am not sure if they will clear on a 6' trailer.
Weight wise it is probably about the same as any 4610, SU meant special utility which I believe consisted of a lighter duty swept front axle, different rear wheels , the hydraulics may be a bit different and maybe a few other things but for the most part that weight is probably pretty close. Whatever trailer you decide to use should be able to handle a heavier machine anyway.
   / How much does a 4610SU weigh? #3
Ask the owner how wide it is.... and if the tires are already set in.. etc.
Soundguy
   / How much does a 4610SU weigh? #4
Most SU's I've seen have either 16.9 x 24 or 14.9 x 28 rear tires. I would think it would be closer to the weight of a 3910 at 4500 lbs.
Thanks to everyone for their replies. I measured the tractor and it was 1/2" wider than my trailer. I bought the tractor and paid the seller to deliver it. I am headed to Alaska tonight for a while and I will post more on my purchase after I return.
   / How much does a 4610SU weigh? #6
Good call ont he seller delivery. Lotsa times owners have ways to move their own tractor.. and making a last delivery of it is a good way to part with it especially if the buyer is not setup to haul it yet.
soundguy
28013 (A50322)
28013 (A50322)
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
