How much does a 4610SU weigh?
   / How much does a 4610SU weigh? #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
Does anyone know how much a Ford-New Holland 4610SU weighs? I looked it up on tractor data and they say a 4610 weighs 5000 pounds but has no weight for the 4610SU which I think is lighter.
The tires are not loaded and there is no other ballast.
Also, will it fit on a 6' wide trailer? They have no data on the width.
I am planning on buying one and need this info to determine how to get it home.
   / How much does a 4610SU weigh? #2
Depending on tire size, fitting that on a 6' wide trailer will be tight, or it probably won't fit. You may be able to bring the wheels in as far as possible but I am not sure if they will clear on a 6' trailer.
Weight wise it is probably about the same as any 4610, SU meant special utility which I believe consisted of a lighter duty swept front axle, different rear wheels , the hydraulics may be a bit different and maybe a few other things but for the most part that weight is probably pretty close. Whatever trailer you decide to use should be able to handle a heavier machine anyway.
   / How much does a 4610SU weigh? #3
Ask the owner how wide it is.... and if the tires are already set in.. etc.
Soundguy
   / How much does a 4610SU weigh? #4
Most SU's I've seen have either 16.9 x 24 or 14.9 x 28 rear tires. I would think it would be closer to the weight of a 3910 at 4500 lbs.
Thanks to everyone for their replies. I measured the tractor and it was 1/2" wider than my trailer. I bought the tractor and paid the seller to deliver it. I am headed to Alaska tonight for a while and I will post more on my purchase after I return.
   / How much does a 4610SU weigh? #6
Good call ont he seller delivery. Lotsa times owners have ways to move their own tractor.. and making a last delivery of it is a good way to part with it especially if the buyer is not setup to haul it yet.
soundguy
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
1986 Nissan King Cab Pickup (A52384)
1986 Nissan King...
2025 Icon Electric Cart (A51694)
2025 Icon Electric...
