4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,946
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
You arent lightening the weight on the axle to less than before you picked the heavy load on the loader. You are just taking a percentage of the load off.
There have been several threads on here a year or 2 ago on this debate. If I recall the skeptic was going to prove us all wrong. He ended up posing some good numbers indicating a reasonable reduction in front axle weight regardless of a load on the loader or not when proper ballast was used. I'm sure you can search up the thread with some digging.
I’ve seen several such threads and you definitely aren’t saving the front axel with an average amount of ballast. It would take thousands of pounds or a boom pole to “save” the front axel. Adding 750 pounds to a tractor this size is definitely not enough to reduce the front axel load. I really doubt 1000 pounds is.
