How much ballast for a 40hp machine (TC40DA)
   / How much ballast for a 40hp machine (TC40DA) #1
Fields_mj
Central Indiana
Ford 1710, Kubota F2880, White FB16
I'm curious how much ballast weight someone would recommend for a 40hp tractor and loader. This past Jan I picked up a (new to me) TC40DA with a cab. It doesn't currently have any ballast. Picking up IBC totes stacked full of seasoned hickory is enough to almost lift the back wheels off the ground. I've been making do this summer by running it in 4wd. My yard is flat, and I'm only lifting them less than a foot, and I'm leaving the hydrostat in low range while moving them. Regardless, I want to add some weight for both safety sake, and to add traction. Per Tractordata.com, the tractor weights around 3500 lbs empty. I'm guessing that the 250TL loader and cab adds another 1,000 lbs.
My old tractor is a Ford 1710. Its a 4wd, but its missing some of the gears so its functionally a 2wd. With the 770 Loader and wheel weights, I'd estimate it weighs 3500 lbs. It has AG tires and I had them loaded with beat juice (32 gal each) and that made a HUGE difference in traction. That brought the total weight to around 4,200lbs. It handles well, but it also made it to where I absolutely can not use it when the ground is soft. The new tractor has 17.4x24 industrial tires and I was able to move it in much softer conditions without rutting things up this spring. I'm not ruling out putting SOME beat juice in the rear tires (they hold 55 gal ea), but I'd like to try adding a home made ballast box first and see how I like that. The question is how much to add. I have access to 30 gal and 55gal poly drums. My math says a 30gal drum of concrete weighs 600 lbs, and a 55 gal drum weighs closer to 1,000 lbs. I haven't done much work with the 3 pt, but Tractordata.com says that its lift capacity is +2300 lbs at 24" so it should do fin with 1,000 lbs, but I also need to be able to lift those IBC totes of firewood at the same time....
Thoughts/opinions???
Thanks,
Mark
   / How much ballast for a 40hp machine (TC40DA) #2
My tractor is similarly sized and the owner's manual recommends 700lbs. I also used a plastic barrel with one of these Amazon hitches filled with concrete to just under 1,000lbs and it works great and cost less than $100. Ballast on the 3 point is much more useful for counteracting loader weight than filled tires, and relieves more stress from the front axle. I'd suggest 1,000lbs for you.
   / How much ballast for a 40hp machine (TC40DA) #3
I’m going to say 1000 pounds minimum, 1500 might be better. The owners manual might say. If your tractor will lift it and almost be picking up the rear tires that is severely overloading the front axle. I’ve done it also but usually because I’m too lazy to hook up the ballast box. I’ve stopped doing it to because of how bad it overloads the front compared to its spec.
   / How much ballast for a 40hp machine (TC40DA) #4
I would agree that 1000 lbs would be a good starting point, along with the 55 gallons of fluid in the tires. I like having the loaded rear tires for traction, and generally use my 735 lb ditch bank flail for 3 point ballast. Setting the flail at its furthest to the rear and centered position (maybe around 4' from the pins?) is a fair amount of ballast for loader work.
   / How much ballast for a 40hp machine (TC40DA) #5
Our TC40DA has a Red Master II arena drag on it all the time. It weights 816# and sticks out a bit so leverage helps. The tires are not loaded. I have maxed out the loader lifting pallets and didn't have an issue with the rear wheels getting light. I do go slow with the weight low so as to not have issues.
That's why I'm bumping this up on the priority list. I'm basically putting over 5k on the front axle which is a no-no. So far, I've only moved 9 boxes about 100ft each, this practice needs to stop.
If I load the rear tires, it won't be with 55gal in each tire. I don't want a machine that weighs well over 5k empty. Fluid in the tires gains me traction, but it doesn't get weight off the front axle. I'll start with a 55gal drum full of cement and see how things go. If it seems like I need more, I'll probably try to find a way to add more weight to the rear hitch so long as its not decreasing my loader's lift capacity. The more I can add back there, the more weight I take off the front axle, and the easier it is on the drivetrain.
   / How much ballast for a 40hp machine (TC40DA) #7
Mark, reading through your original post, in my mind the most important reason you give for adding weight would be so you can stop running it in 4wd with a load in the FEL.
Compact tractors have a part time 4wd assist; they aren't intended to carry a load around in 4wd.
Driving any distance in 4wd with a heavy FEL load is a good way to get into costly repairs.
Of course you could always just not stack th IBC totes so full. That would solve most of the problems and cost nothing, but it is still good practice not to run it in 4wd any distance.... even without a load.
rScotty
   / How much ballast for a 40hp machine (TC40DA) #8
Sounds like a plan. You have a good understanding of 3 point ballast vs loaded tires, which occasionally gets argued here on TBN.
I personally like having the full (75%) loaded tires, as I need all the weight I can get for snow plowing. I am considering adding 600lbs of iron to the rims (total) if I can ever get over the cost!
   / How much ballast for a 40hp machine (TC40DA) #9
I know you could make something cheaper. But you'd probably have half of this in it by the time you buy concrete, hardware, etc. Wouldn't you? This is a pretty easy way to add ballast and they'll deliver it to your door -- free. I filled mine with gravel and then hung some brake rotors on rods inserted into the vertical holes. Haven't weighed it but it did the trick. (This is just an example -- there are dozens of options online from different vendors.)
   / How much ballast for a 40hp machine (TC40DA) #10
The Tractordata info is wrong, it will not lift that much. I struggle with my 16LA loader, the previous model to the 250TL, to get a pallet with 1500# off the trailer with my Land Pride PFL3048 SSQA forks which weigh 358#. If I can tilt the load back over the pins without dumping stuff off, it helps a lot. The NH website says the max lift for the model 250TLA is 1822# at the pin, 1354# at 24" (500mm). It would be even less with the pallet sticking out 36"-48" in front, plus add the weight of the pallet forks. That is to max height but it won't do much better at lower heights. That decreases the amount of ballast you need to be stable. Based on those numbers and since you have the cab weight, 600# of ballast should work but 1000# won't overload the machine.
UNUSED FUTURE 19" EXCAVATOR RAKE (A52706)
UNUSED FUTURE 19"...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A52706)
UNUSED RAYTREE...
