How much 2 cycle engine oil can be safely added to diesel
   / How much 2 cycle engine oil can be safely added to diesel #31
also just thinking last I knew ATF had friction characteristic to it. the reason oil does not work in auto transmission. seems that ATF could be worse to use.
   / How much 2 cycle engine oil can be safely added to diesel #32
Where do you get the info ULSD "almost certainly does" have "Bio" in it?
If you have a source for that info please tell us....I'd love to have 1-2% bio in my diesel fuel, but don't see that happening unless I add it, and I do when I have it. I pick up some B99 and use it as an additive, problem is I can only get it 150 miles away, in Asheville NC. When I don't have it, I use 2 stroke oil. BTW the B99 does NOT store well, starts smelling a little rancid after a few months.
While "most" states do not have a Bio-D mandate, states that sell a lot of fuel do, so the refiners are ramping up production.
I have not seen a mandate to display "Bio-Diesel" on any pump with it, but it SHOULD be required as should Cetane (N+I/2) as with Octane.
NPRA | State Motor Fuels Specification
Partial listing of Bio-D suppliers/stations: Biodiesel ? Petroleum Diesel ? B20 Refining ? Green Fleet
Bio-D pumps: refiners offering biodiesel - Google Maps
Bio-Diesel sale is generally concentrated in high population density areas, or ones with PM pollution challenges. *Most* citizens of the US have BD available to them, but it may not be at their normal filling location.
   / How much 2 cycle engine oil can be safely added to diesel #33
Well I dont think bio diesel has made its way to central maine yet so my question still stands
Your answer was offered in the very first reply.
   / How much 2 cycle engine oil can be safely added to diesel #34
   / How much 2 cycle engine oil can be safely added to diesel #35
Zombie thread, but still informative. I was surprised to see that people burn ATF fluid for fuel; I used to add a bit into the crankcase of old engines to clean and rejuvenate them. Sometimes it worked, other times it cleaned all of the crud out which was the only thing keeping them from falling apart.
   / How much 2 cycle engine oil can be safely added to diesel #36
I use 3.2 ounces of 2 cycle marine oil per 5 gallon diesel fuel can when I fill them. I think that works out to about 200:1 ratio. Works for me summer and winter here in NC in my old 861D Ford. I read if temps get below 20 degrees you should use anti-gel, but I've been fine just using the 2 cycle marine oil as an additive as temps rarely get below that here for very long at a time.
   / How much 2 cycle engine oil can be safely added to diesel #37
A diesel mechanic that I trust uses ATF at every fill-up in his Ford 7.3 diesel. I have not seen research on ATF added to diesel but the results on used motor oil was negative. Last night I printed out the results of this very old research to take to him today.
   / How much 2 cycle engine oil can be safely added to diesel #38
Interesting thread and something I had not considered before. But, my tractor has a Cummins diesel and when I was doing some reading, Diesel Clean & Cetane Boost was the only thing recommended by Cummins so I bought some. My rough math, the bottle is designed to treat 100 gallons of i remember right, told me to put 1.5 oz in 5 gallons so that's what I've been doing. Doesn't cost near what the below says though.
From the 2007 report
Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
   / How much 2 cycle engine oil can be safely added to diesel #39
Keep in mind how dated the data is. It may still be spot on or not.
   / How much 2 cycle engine oil can be safely added to diesel #40
And make sure that whatever you put in will not hurt the diesel particulate filter (if your tractor is big enough to be equipped with one of those).
Aaron Z
1977 Cat 910 Wheel Loader (RUNS) (A50774)
1977 Cat 910 Wheel...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
Wolverine Quick Attach Hydraulic Slide Pallet Forks (A50515)
Wolverine Quick...
2022 McConnel TRAXX RC28 Remote Controlled Slope Mower (A51691)
2022 McConnel...
