How Many Rear Remotes?
/ How Many Rear Remotes? #21
I have a New Holland 4835 with 4 hydraulic outlets. I have a loader that takes up all 4. I need 2 more to operate my batwing. Any ideas what I can do about this?
/ How Many Rear Remotes? #23
If you don't need all 4 ciruits for the loader when the Batwing is hooked up, put selector valves on 2 circuits and use those.
/ How Many Rear Remotes? #24
I tried to hook the mower to my tilt outlets for the loader so I could still raise and lower the loader if I needed to. However it blew a hydraulic line and it would not work. The only way it would work if I used the outlets for raising and lowering the loader. So I figure I needed to add more outlets because I know their will be times I need to raise the loader while cutting.
/ How Many Rear Remotes? #25
Hooking it to the tilt line outlets shouldn't cause it to blow a hose.
Year: 2008 Make: GMC Model: Yukon XL Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 221,739 (A61574)
Year: 2008 Make...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
iDrive TDS-2010H...
Quick Hitch Mini Excavator Attachment (A61572)
Quick Hitch Mini...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
