How Many Rear Remotes?
/ How Many Rear Remotes? #21
I have a New Holland 4835 with 4 hydraulic outlets. I have a loader that takes up all 4. I need 2 more to operate my batwing. Any ideas what I can do about this?
/ How Many Rear Remotes? #23
If you don't need all 4 ciruits for the loader when the Batwing is hooked up, put selector valves on 2 circuits and use those.
/ How Many Rear Remotes? #24
I tried to hook the mower to my tilt outlets for the loader so I could still raise and lower the loader if I needed to. However it blew a hydraulic line and it would not work. The only way it would work if I used the outlets for raising and lowering the loader. So I figure I needed to add more outlets because I know their will be times I need to raise the loader while cutting.
/ How Many Rear Remotes? #25
Hooking it to the tilt line outlets shouldn't cause it to blow a hose.
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
Location (A63111)
Location (A63111)
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
KMC 3pt 5' Rotary Tiller (A64119)
KMC 3pt 5' Rotary...
