When you change antifreeze, always remove the vent plug that's probably on top your thermostat housing. Think my 4010 manuals/CD don't mention this, but the stuff really won't drain out until you remove that vent. It's easier to refill, too. Just fill until you see some come out the vent. Then put the vent plug back in and add until radiator is full. Then put some mix into the overflow pot. I do this on my tractor, the Benz and the Toyota. The Toyota doesn't have a vent, but I took out the temperature gauge sensor and put back. Haven't found out really what to do on the silly VW with the thermostat on the bottom. Changed its antifreeze twice, and it was a struggle to drain and to refill both times.
