how many hp for cutter
   / how many hp for cutter #1
Debbie Ra
Ford 9n
How many Hp should my tractor have to run a 5' rotary cutter
   / how many hp for cutter #2
5 hp per foot seems to be the rule of thumb on here, but you could likely get by with 20-25 hp if the cutting's not too tough.
Thanks
   / how many hp for cutter #4
There is a size/weight element to this, in addition to horsepower. Most people would say a sub-compact tractor (like a Kubota BX series) may have enough horsepower for a 5ft cutter, but the tractor itself is too small and light for a cutter of that size.
   / how many hp for cutter #5
5 hp per foot is a rough rule of thumb but will vary a lot depending on the weight of your cutter and what you are cutting. There are 5 foot cutters that wiegh 3 times more than others - and could outweigh what the hitch can lift. Cutting rough brush is a lot different than cutting grass/hay in a field.
   / how many hp for cutter #6
Just put my OLD JD 5' Gyro mower on the JD 790 (27 HP) today, plenty for weight! I was mowing field edges, mostly brome grass & weeds that hadn't been cut yet this year. No power problems, although it did work it some when I got into some heavy Reed's Canary grass. This is a one day/ year job, so no reason to buy a newer mower when the old Jd was already there! ~~ grnspot110
   / how many hp for cutter #7
I run a 5' Rhino with a Mahindra 2615 with 26 hp (23 pto hp if I remember correctly). I have cut heavy grass, weeds, and briars/woody vegetation taller than the tractor with no problems. As others have said you must consider hp and weight of the cutter.
   / how many hp for cutter #8
Does the 5hp / ft. guideline change for finish mowers? Or should that be the subject of a separate thread. I have a 34hp tractor that delivers 26hp at the PTO. Feels like it cuts through heavy brush nicely with a 5' shredder. Wondering if my finish mower should be 5' or 6' -- not much difference in implement cost; hoping I have the hp for a 6' RFM.
   / how many hp for cutter #9
You could easily run a 6' mower with 26 PTO HP. A 5' cutter is also the right size for your Kioti.
There's nothing hard and fast about the 5 HP per foot "rule". My first tractor was 16.5 PTO HP and did a fine job with a 5' cutter. It was slow going though.
   / how many hp for cutter #10
I think it is like the brush hogs where we could go on and on.
I think with a finish mower you want more power, not saying 35HP isn't enough for a 5-6ft finish mower but you will notice thick or tall grass, compared to a brush cutter where you will go right through grass that is rubbing the belly of the tractor.
I also want to be able to mow the yard with a little pace, I usually use 3rd low (iirc) is about 2-4mph depending on hills. I don't want to have to crawl.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
