How many hours you put on your compact each year?
   / How many hours you put on your compact each year? #51
That certainly does bring back memories, Rat. You got a big enough cup, tractor and 4-in-1 bucket to wear that signature? /forums/images/graemlins/wink.gif
   / How many hours you put on your compact each year? #53
Just over 300 hours added in two years on a JD4300. No mowing unless you count brush hoggin too. The Yanmar (1500) will get the mowing hours from my wife mostly...she works harder than I do...yep I'm a lucky man.
Peter
   / How many hours you put on your compact each year? #54
My 4600 gets about 700 hours a year on it. It's used everyday for chores. I can't believe how well this thing is holding up. I abuse the heck out of it and it's still going strong with over 2000 hours on it. Knock on wood no repairs yet.
   / How many hours you put on your compact each year? #55
I am at 50 hours after owning my L3830 for 9 months. I use it for finish mowing, bush hogging about 10 acres and some light box blading when the chance comes along. No snow removal needed here is Mississippi!!
Lawrence
   / How many hours you put on your compact each year? #57
lookin like 75 to 100 hours per year. mowing and some snow removal.
   / How many hours you put on your compact each year? #58
Looks like I might be the low hour king. I just made my 30th payment and my hourmeter shows 96, so less than 40 hours per year.
To be fair, I rarely shred, just don't have the need. I do mostly loader and boxblade stuff (about 2000 rpm avg) and a little bit of post hole digging. So I'm on my tractor a bit more than that.
Although this is far fewer hours than I expected to put on the tractor, I use it frequently and whenever I need it. The time savings are tremendous. I've also done quite a bit of dirt reclamation and transport for my yard and have no doubt that I've more than paid for the depreciation on my tractor in work and product output.
When I casually mentioned to my wife that soon I might have little need for my tractor she glared at me and said in no uncertain terms that the tractor will NOT be sold. Not that I had any intention of doing so, but a quick test of the waters is always informative. /forums/images/graemlins/smile.gif
   / How many hours you put on your compact each year? #59
150 hours per year on 4 CUTs over 8 years---now a 4710 that I wouldn't be without...I do all the "chores" with it...
JackD
You know John, just the convenience of having it around has immeasurable advantages. I suppose whether I put on 25 hours a year or 700 hours like CowboyDoc does, the added value of always having it there just to use it to lift a heavy object out of your truck if it's equipped with a loader or moving a pile of dirt to whatever else you find advantageous ti use a tractor on can be all the reason one needs to justify having it. Heck, if it's just something you always wanted, that should be enough. Rat.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
