How many hours you put on your compact each year?
   / How many hours you put on your compact each year? #51
That certainly does bring back memories, Rat. You got a big enough cup, tractor and 4-in-1 bucket to wear that signature? /forums/images/graemlins/wink.gif
   / How many hours you put on your compact each year? #53
Just over 300 hours added in two years on a JD4300. No mowing unless you count brush hoggin too. The Yanmar (1500) will get the mowing hours from my wife mostly...she works harder than I do...yep I'm a lucky man.
Peter
   / How many hours you put on your compact each year? #54
My 4600 gets about 700 hours a year on it. It's used everyday for chores. I can't believe how well this thing is holding up. I abuse the heck out of it and it's still going strong with over 2000 hours on it. Knock on wood no repairs yet.
   / How many hours you put on your compact each year? #55
I am at 50 hours after owning my L3830 for 9 months. I use it for finish mowing, bush hogging about 10 acres and some light box blading when the chance comes along. No snow removal needed here is Mississippi!!
Lawrence
   / How many hours you put on your compact each year? #57
lookin like 75 to 100 hours per year. mowing and some snow removal.
   / How many hours you put on your compact each year? #58
Looks like I might be the low hour king. I just made my 30th payment and my hourmeter shows 96, so less than 40 hours per year.
To be fair, I rarely shred, just don't have the need. I do mostly loader and boxblade stuff (about 2000 rpm avg) and a little bit of post hole digging. So I'm on my tractor a bit more than that.
Although this is far fewer hours than I expected to put on the tractor, I use it frequently and whenever I need it. The time savings are tremendous. I've also done quite a bit of dirt reclamation and transport for my yard and have no doubt that I've more than paid for the depreciation on my tractor in work and product output.
When I casually mentioned to my wife that soon I might have little need for my tractor she glared at me and said in no uncertain terms that the tractor will NOT be sold. Not that I had any intention of doing so, but a quick test of the waters is always informative. /forums/images/graemlins/smile.gif
   / How many hours you put on your compact each year? #59
150 hours per year on 4 CUTs over 8 years---now a 4710 that I wouldn't be without...I do all the "chores" with it...
JackD
You know John, just the convenience of having it around has immeasurable advantages. I suppose whether I put on 25 hours a year or 700 hours like CowboyDoc does, the added value of always having it there just to use it to lift a heavy object out of your truck if it's equipped with a loader or moving a pile of dirt to whatever else you find advantageous ti use a tractor on can be all the reason one needs to justify having it. Heck, if it's just something you always wanted, that should be enough. Rat.
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
1611 (A57192)
1611 (A57192)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
2001 International 4000 DT 466E (A60462)
2001 International...
