How many hours on your tier 4 tractor
   / How many hours on your tier 4 tractor #41
No I have the shuttle transmission. I do a lot of scooping and pushing and piling with my loader. Every couple of months I will scoop and pile 75 tons or so of manure. Plus feeding hay and moving hay rings. Was afraid of the HST for pulling the decruster.
   / How many hours on your tier 4 tractor #42
Is there any info on how many regens you do before the DPF needs service. I would bet the the number varies by model
One thing I would like to add is at the time I was shopping for my tractor Case one one name I was interested in but the dealers around here wouldn't even show me one because they said they were having major issues with all the tier 4 stuff. Anyone have any knowledge of this and know if they got it all straightened out?
   / How many hours on your tier 4 tractor #44
MX 5200. 92 hours. Everything has been working fine and functionally no issues. 5 regens so far and the last one just happened. I think I average about 15 to 20 hours between. I have a horse farm and drive manuer from the barn every day....which in the winter time is really not ideal for a dpf machine. When it's cold I preheat for ten minutes at 1350 rims as per the manual....then how many rpms are really needed to haul my 1 or 1.5 buckets of manuer to a compost pile 150 yards away.....I'm either wasting gas at 1800 or 2000 rpms or clogging the dpf at 1350. My other use lately has been clearing a few acres of land from woods....making pasture. For that I keep it between 1800 to 2000 rpms with a lot of stopping and restarting and switching between the bucket to push small trees down and the forks to carry everything away. I try not to leave the machine idle and keep the rpms high when in use.
BUt mentally it does kind of suck often trying to find the line between knowing your using more gas than you need to and trying not to plug your dpf all the time. There are other situations I don't like either. I hate the idea of stopping a regen cycle mid way. So if one pops on I like to see it through. Twice now while loading loggs onto trailers this has created small issues. One time just as I finished loading my cousins trailer the dpf needed clearing. I wanted to show him something else on the property so instead of shutting it down mid cycle I left it run and we went for a walk. Well between conversation and important discussion it took a good half hour before I made it back to the machine which was running about 2000 rpms. I kept thinking as I'd hear the tractor run ,"what a huge waste of gas and machine wear". I didn't see that regen light pop on so for all I know it could have been almost done cycling when I got off the tractor...then another pointless how many minutes of high rpm run time? Another situation very similar to that happened when I finished loading another trailer and looked down before shut-off and noticed the light on. I needed to talk to the trailer driver and it would have been nice shutting the machine off. Instead I climbed off the machine leaving the engine screaming at 2k. Explained why I left it running...dang epa...then we had to shout over the engine noise to finish our conversation about what needed done.
I've only had the machine for about 3 or 4 months but these are my experiences so far. 3 out of 5 regens have come at bad times. And I'm often making compromises between wasting gas and worrying about the dpf...etc. don't get me wrong I love the tractor and am awed by its capabilities...but the people pretending there are no problems or compromises at all must be drinking hard coolaid or they just haven't experienced them yet. I find myself, even though these issues aren't big ones they are small inconveniences, wishing I would have bought a few years ago.
I think the same way you do all though I haven't been inconvenienced by mine yet I see it coming eventually. But the way I see it is I am a young man and this is only going to get worse so I just as well get used to it all.
FWIW you do realise you can push the button to delay as soon as you get on the tractor and start it up that way if yoh have a quick task to do it'll hold off till the next time you get on.
   / How many hours on your tier 4 tractor #46
snip.....
Luckily mine is used mostly for mowing so I would suspect they will usually happen when running pto rpm anyway. But yea for your situation that defiantly is a huge inconvenience.
Another regen today at 75 hrs still no issues. One observation though is after every regen the exhaust note gets deeper more tractor like to me.
   / How many hours on your tier 4 tractor #48
So what is this regen and dpf you all are talking about?
   / How many hours on your tier 4 tractor #49
DPF = Diesel Particulate Filter, is a device designed to remove diesel particulate matter or soot from the exhaust gas of a diesel engine.
Regen = Regeneration, is the process of removing the accumulated soot from the filter. This is done either passively (from the engine's exhaust heat in normal operation or by adding a catalyst to the filter) or actively introducing very high heat into the exhaust system.
   / How many hours on your tier 4 tractor #50
I didn't worry either. My new F3990 did two regens then at 45hrs. failed and spent over a month at the dealers shop last fall. I can hardly wait for spring to see what great adventure awaits.
   / How many hours on your tier 4 tractor #51
First regen at 17 hours, next at 57, have about 70 hours now...no issues with tier 4
Seems new technology scares some out there, fuel injection used to be a new thing, as was electric starters, even rubber tires!
Who knows what the future holds?
Another regen at 73.3 hrs. A lot of backhoe work in cool weather, trenched 180' x 2' deep, and pulled a couple old stumps. Regened while using the hoe...decreased power for 5 minutes but didn't affect my fun!
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2018 VOLVO L180H WHEEL LOADER (A60429)
2018 VOLVO L180H...
