How Many Hours Do You Spend on Your Tractor(s)?
   / How Many Hours Do You Spend on Your Tractor(s)? #21
Open cab fully restore to new condition when I got the YM2610 in 2014. Nearly put 1,000 hours on it. When covid hit in 2020, people couldn't get anyone to till gardens. It was the best seat time I had ever had. IF I eve retire, it would be the job of choice.
So, 1,000 in 1 decade or 100avg hours per year.
   / How Many Hours Do You Spend on Your Tractor(s)? #22
Open station 75 hrs a year. Mostly cutting fields, building and maintaining trails.
Retired in 2003 and bought a used gray market Mitsubishi 33 HP, by 2021 it was worn out so I bought a new LS 40hp 2021.
   / How Many Hours Do You Spend on Your Tractor(s)? #23
I have 5 tractors, but only 2 operators. My use is about 90% business and 10% use around my shop and on about 65 acres of land that I own but is rented out to a hay farmer. We tend to use the newer tractors more, because they are more comfortable.
Here is a list of approximately how many hours and annual use each has.
2022 Kubota L6060 cab -- 450 hours -- about 225 hours per year
2017 Kubota L6060 cab -- 1600 hours -- about 225 hours per year
2011 Kubota L5740 cab -- 2700 hours -- about 205 hours per year
2013 John Deere 3720 cab -- 850 hours -- about 75 hours per year (I bought this tractor about a year ago, and I've put about 50 hours on it.
1997 Kubota M4700 open -- 1050 hours -- about 40 hours per year (I bought this tractor about 3 years ago and have put about 50 hours on it. I keep it as a spare)
   / How Many Hours Do You Spend on Your Tractor(s)? #24
In 24 years I put 4500+ on a BX and in 2 1/2 years I put a bit over 400 (650 total) hours on the LS. Still use the BX quite a bit but other machines have taken more of the load.
   / How Many Hours Do You Spend on Your Tractor(s)? #25
About 20 per year on the TYM 4820 and 40 hours per year on the Hustler 72" mower.
Not a lot of time, but the work wouldn't get done without them.
   / How Many Hours Do You Spend on Your Tractor(s)? #26
My newest is the 2007 NHTD95D has over 4000 and is the lowest hours of all of them. 2 JD's are over 10,000, 2 others are at 8,xxx. IH didn't work when I got it so unknown. Has 3,5xx on working tach now. The most used tractors average 300 hours a year.
   / How Many Hours Do You Spend on Your Tractor(s)? #27
My 4110 Mahindra is open station with a very bent-up/repaired steel canopy on the ROPS. Built in 2001, I purchased new in Feb 2002 with 3.6 hrs on the clock. It now has 3224 hrs. Still gets used year 'round but far fewer hrs. per year and much lighter duty work.
   / How Many Hours Do You Spend on Your Tractor(s)? #28
~140 hours per year between the two.
   / How Many Hours Do You Spend on Your Tractor(s)? #29
Im on my second year with mine and Im almost at 100 hours so 50 hours a year or so for me. Mines an open station, dont use it much in the winter.
   / How Many Hours Do You Spend on Your Tractor(s)? #30
I only put a few hours per year on now. I bought the 1999 Kubota in 2003 with 350 hours on it. I've put about 500 hours on it in 21 years. I probably put less than 10 per year now but those are important hours when trying to get in and out of our property in the winter.
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2025 AGT MX15RX Mini-Excavator with Dozer Blade (New/Unused) (A59225)
2025 AGT MX15RX...
2019 Kaufman Pro Series Car Hauler Trailer, VIN # 5VGFE4736KL004723 (A57453)
2019 Kaufman Pro...
(3) CASES OF NEW PLATES (A58374)
(3) CASES OF NEW...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
