How many hours do you have on your 20 hp kohler?
   / How many hours do you have on your 20 hp kohler? #1
Terre Haute
T5D
My engine is a 2004 and I have 1950 hours on T5C. It's Still running strong. Doesn't use oil. I change it every 50 hours. What is the life expectancy of the Kohler?
If yours blew up, what happened?
   / How many hours do you have on your 20 hp kohler? #2
I have owned 4 or 5 welders with Kohlers and they were all well maintained, I usually sold them at around 2000 hours because they would be starting to rattle a bit and would usually be weeping some oil by then. I have seen some machines for sale with 3000+ hours but they looked pretty beat.
   / How many hours do you have on your 20 hp kohler? #3
I have a Bolens with a 20hp Kohler, it has a little under 500 hrs on it and has been treated very good...
It runs good but it does burn oil, so I have to watch the oil level pretty close.
SR
   / How many hours do you have on your 20 hp kohler? #4
Mine had 900 hours when it burnt. The root cause was poor design. The direct cause was a fuel line coming loose and poring gas on the muffler. Mine didn’t burn oil and still started good.
   / How many hours do you have on your 20 hp kohler? #5
I have a 1996 Exmark Lazer Z 60" with a 25hp kohler horizontal engine. It has 3750 hours on it. Uses a little oil after cutting 12 acres. But still runs great the only thing I have had to replaced were coils once.
   / How many hours do you have on your 20 hp kohler? #6
I have a 2000 T5D model with a 20hp kohler with 1800 hours on it. Still running very good. I ask my local lawn care shop that sells kohler engines what kind of service life that the 20hp has and they told me that it should last at least 3000-3500 hours with proper maintenance before it needs a rebuild. Keep fresh oil and filters in it, along with a good set of spark plugs and it will last a long time.
Thanks for your reply. Nice to know. I was worried I'd be buying a new engine soon. I saw a guy with a kohler on a mower. His died because grass choked the cooling fins and valve seat dropped out.
2019 Freightliner M2 106 Utility Flatbed Day Cab Truck Tractor (A55973)
2019 Freightliner...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
Portable Restroom (A54865)
Portable Restroom...
