How many hours do you have on your 20 hp kohler?
   / How many hours do you have on your 20 hp kohler? #1
Terre Haute
T5D
My engine is a 2004 and I have 1950 hours on T5C. It's Still running strong. Doesn't use oil. I change it every 50 hours. What is the life expectancy of the Kohler?
If yours blew up, what happened?
   / How many hours do you have on your 20 hp kohler? #2
I have owned 4 or 5 welders with Kohlers and they were all well maintained, I usually sold them at around 2000 hours because they would be starting to rattle a bit and would usually be weeping some oil by then. I have seen some machines for sale with 3000+ hours but they looked pretty beat.
   / How many hours do you have on your 20 hp kohler? #3
I have a Bolens with a 20hp Kohler, it has a little under 500 hrs on it and has been treated very good...
It runs good but it does burn oil, so I have to watch the oil level pretty close.
SR
   / How many hours do you have on your 20 hp kohler? #4
Mine had 900 hours when it burnt. The root cause was poor design. The direct cause was a fuel line coming loose and poring gas on the muffler. Mine didn’t burn oil and still started good.
   / How many hours do you have on your 20 hp kohler? #5
I have a 1996 Exmark Lazer Z 60" with a 25hp kohler horizontal engine. It has 3750 hours on it. Uses a little oil after cutting 12 acres. But still runs great the only thing I have had to replaced were coils once.
   / How many hours do you have on your 20 hp kohler? #6
I have a 2000 T5D model with a 20hp kohler with 1800 hours on it. Still running very good. I ask my local lawn care shop that sells kohler engines what kind of service life that the 20hp has and they told me that it should last at least 3000-3500 hours with proper maintenance before it needs a rebuild. Keep fresh oil and filters in it, along with a good set of spark plugs and it will last a long time.
Thanks for your reply. Nice to know. I was worried I'd be buying a new engine soon. I saw a guy with a kohler on a mower. His died because grass choked the cooling fins and valve seat dropped out.
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Compressor (A55973)
Compressor (A55973)
