How many gallons of fluid will my tires hold?
   / How many gallons of fluid will my tires hold?
Using the Gempler's tool - the one the releases air automatically as the tire is filled with fluid - I filled the tires this afternoon. Super slick. Anxious to do some loader work to check out the difference 425 lbs in the tires make.
   / How many gallons of fluid will my tires hold? #12
So, how did they work out?
Makes a noticeable difference. Tractor more stable on varied terrain and much less pucker using the bucket.
   / How many gallons of fluid will my tires hold? #14
When I bought my tractor I filled both the front and rears so I wouldn't float in water, -dredging my ponds-and it is amazing what a difference it makes. it's like a tank. my first tractor didn't have filled tires and as soon as I got into the water the tractor would "float".
Wow, you wouldn't think a tractor would float like that. So how did you protect the drivetrain from the water you were driving through?
   / How many gallons of fluid will my tires hold? #16
I wasn't driving all that deep, maybe a foot,but with the big tires as soon as it would get into the water it would start to float. I also have a couple of creeks i cross that are about a foot deep and it would get tippy there also.
   / How many gallons of fluid will my tires hold? #17
Why Methaol Alcohol, why not one gallon anti freeze with water per rear tire? The anti freeze will lower the freezing temperature and inhibit corrosion to the wheels?
2013 Ford F-150 (A53422)
2013 Ford F-150...
LINCOLN ELECTRIC POWER WAVE 455M WELDER (A57192)
LINCOLN ELECTRIC...
(5) Ladders (A56469)
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2008 SELLICK SD-80 STRAIGHT MAST FORKLIFT (A52707)
2008 SELLICK SD-80...
John Deere 5100M (A53317)
John Deere 5100M...
