How Low?????
   / How Low????? #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
I recently had my radiator recored, flushed the engine and installed a 50-50 mix of antifreeze and water. To what temperature will this protect my YM1700?
   / How Low????? #2
50-50 will give about -34ºF
In Alabama, you'd be better off with 30-70% max
   / How Low????? #3
Be very careful. The YM1700 has no water pump and relies on natural convection (thermosyphon) to circulate the coolant. You should use only as much antifreeze as is absolutely necessary to protect your engine from freezing coolant. Ideally, just water works best for cooling in engines without a waterpump. The higher the concentration of antifreeze, the more this natural circulation is inhibited. I live in western MD, and use a 30% antifreeze, 70% water mix in my YM1110D's which don't have water pumps. In Alabama, I would certainly use 30% antifreeze or less.
   / How Low?????
I used it doing some mowing, some tilling and some landscaping after I installed antifreeze and it didn't act like it wanted to over heat. I won't be using it any more until spring, I'll probably change it out then.
   / How Low????? #5
Ditto on the 30/70 mix.. no more than 30% a.freeze.. or just enough to get past the lowest expected cold point.. otherwise it wont circulate good.
Soundguy
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2014 Nissan Pathfinder SUV (A48082)
2014 Nissan...
2022 Club Car...
New/Unused Quick Attach Forks (A48837)
New/Unused Quick...
2013 FORD F550 SHUTTLE BUS (A50505)
2013 FORD F550...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
