How low is your Quick Hitch?
   / How low is your Quick Hitch? #11
Yes, that was my concern. Forgetting about it and dragging it through the mud. I understand it pays to get quite low for some implements, but this is overkill for everything I have. By about 6 inches.
As I said earlier, if your links are adjustable repin them to the higher setting.
As for forgetting about it and dragging it, you already had that problem before you installed the QH.
   / How low is your Quick Hitch? #12
To prevent dragging ballast or other implements on to low QH....
281055d1347893789-ford-depth-limiter-chains-img_0368-jpg
Dale
   / How low is your Quick Hitch? #13
On some tractors with 3pt position control the lower limit can be adjusted.
   / How low is your Quick Hitch? #14
The problem being discussed here is from owners with tractors that don't have position control. The 3pt leaks down without their knowledge.
   / How low is your Quick Hitch? #15
If you have a simple (old school) control, and don't need height limiting, you could use the stop for lower limiting, or get (or make) another for BOTH.
Yes that sounds good. I have one stop on there, currently set from my last "box blade" run. i will just adjust it a bit lower. It will leak down, but slooooowly with such a low weight.
   / How low is your Quick Hitch? #17
Get a carriage bolt, flat washer, split/lock washer and a wing nut and you have a lower travel limit.
Takeuchi TL12V2 (A53317)
Takeuchi TL12V2...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A55852)
2003 Chevrolet...
2015 John Deere 8370R (A53317)
2015 John Deere...
2018 Ford Transit 150 Cargo Van (A55852)
2018 Ford Transit...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
