How low is your Quick Hitch?
   / How low is your Quick Hitch? #11
Yes, that was my concern. Forgetting about it and dragging it through the mud. I understand it pays to get quite low for some implements, but this is overkill for everything I have. By about 6 inches.
As I said earlier, if your links are adjustable repin them to the higher setting.
As for forgetting about it and dragging it, you already had that problem before you installed the QH.
   / How low is your Quick Hitch? #12
To prevent dragging ballast or other implements on to low QH....
281055d1347893789-ford-depth-limiter-chains-img_0368-jpg
Dale
   / How low is your Quick Hitch? #13
On some tractors with 3pt position control the lower limit can be adjusted.
   / How low is your Quick Hitch? #14
The problem being discussed here is from owners with tractors that don't have position control. The 3pt leaks down without their knowledge.
   / How low is your Quick Hitch? #15
If you have a simple (old school) control, and don't need height limiting, you could use the stop for lower limiting, or get (or make) another for BOTH.
Yes that sounds good. I have one stop on there, currently set from my last "box blade" run. i will just adjust it a bit lower. It will leak down, but slooooowly with such a low weight.
   / How low is your Quick Hitch? #17
Get a carriage bolt, flat washer, split/lock washer and a wing nut and you have a lower travel limit.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
UNUSED JCT 84" HYD 4N1 BUCKET (A57193)
UNUSED JCT 84" HYD...
2013 KUBOTA RTV900 (A57192)
2013 KUBOTA RTV900...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
