How long has the RTV been made?
   / How long has the RTV been made? #42
For the record that's not some small lawn mower your neighbor with a 1/2 acre lawn uses.
   / How long has the RTV been made? #43
   / How long has the RTV been made? #44
The driver of the ranger isn't the smartest cookie I take it...
I knew the lawn mower wasn't a Home Depot special but I would think both units would be at minimum equal weight if the XUV didn't edge it. Plus, the X595 has turf tires on it from the looks and the XUV has what appear to be standard ATV tires. If you figure equal weight and equal power then traction should easily have been in the XUV's favor so unless the X595 is made from lead why wouldn't the XUV pull the tractor backwards:confused:
What about the guy who had the bright idea to stand on the rear bumper of the ranger as the RTV tried to yank it out:rolleyes:
Second try he smartened up and hopped into the box and is lucky he didn't bust his head open when the RTV yanked on it.
   / How long has the RTV been made? #47
that xuv should have pulled it . if they had the same weight and enginesthe only diferencs was the xuv had 4 tires pulling instead of the tractor that just had two somthing wrong there???
   / How long has the RTV been made? #48
The X595 has lower gearing. They look evenly matched. :)
What good is gearing without traction?
   / How long has the RTV been made? #50
None.
Both were spinning. I would like to see it on asphalt. Just not with mine. :)
I'm sure the diesel xuv would out pull the gas model..
2017 Genie GTH-5519 (A53317)
2017 Genie...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
1991 FREUHAUF 40FT BELLY DUMP TRAILER (A57880)
1991 FREUHAUF 40FT...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
