How long for dirt to settle?
/ How long for dirt to settle? #1
snooks
Virginia, IL
YM2500
I tore down a house about 3 years ago. I used my Yanmar 2500 with loader to fill in the basement after removing brick and concrete. The house was on a hill and therefore I was able to dig a road/ramp on the lower end of the basement to make it easy to get loads of dirt into the basement. Since the house sat on a hill, I used surrounding top soil (Central Illinois black dirt) to fill the hole and to lower the elevation of the lot. Since I have done this I have notice some settling, but not a lot. I would like to build a slab foundation over this area. How long should I wait? Would it be better to dig the dirt back out and tamp in sand? Maybe go ahead and put in a basement? Please help.
/ How long for dirt to settle? #2
I would expect if this is an area that can freeze, as well as get 'rained' on, then in three years it has settled all it's going to.
However, if not saturated with rain, not been frozen and thawed, and/or a high clay content, it will likely not be stable for a slab that will stay put.
One can make a floating slab that will have a lot of reinforcing in it, and use the fiber concrete, that probably will just stay together on top of any moving soil beneath.
yes it does get rain and does freeze. Most of the dirt was black top soil and not much clay. I spread it pretty thin and drove over it as well as pressing it in with the bucket. Like I mentioned, in three years I really only have one low spot where its settled and it really isn't that much. To be honest I had expected it to settle more than it has. I'll see what others might add, but like you I think a little more reinforcement should do the trick. Thanks for the input...
/ How long for dirt to settle? #4
You've asked a question without an answer. Disturbed soil can take decades to regain compaction on it's own. How deep is the hole, what type of soil, how clean is it, does it have any organic material are all questions that nobody knows without digging it out and filling it properly.
What you really need to be asking is how do you build on disturbed soil that wasn't properly compacted. A floating slab is one alternative, but to do one right is fairl complicated. Piers dug down to a solid base is another method.
On the jobs I did in California, we had to reach 98% compaction to pass the inspection to build on top of fill. This takes allot of heavy equimpent designed to do this. Here in Texas nobody seems to care, Just lay your fill in layers and drive over it a bunch and your fine. Crazy, but it just goes to show how impossible to answer your question is.
Good luck,
Eddie
/ How long for dirt to settle? #5
</font><font color="blue" class="small">( yes it does get rain and does freeze. Most of the dirt was black top soil and not much clay. )</font>
That's usually bad news.
Black topsoil can take forever or longer to compact.
I would dig that puppy out and fill it with red fill sand. It's pretty cheap. Fill it wider than you need just to be sure. If you have time, fill it to within 1 foot of full, wet it down until water stands on top, then finish by rounding it off to shed rain. Let it dry and settle for several months and you have a foundation that is virtually incompressible.
A little off the main topic, but in my opinion, limestone is the best foundation material for soggy soil areas. Dig 2-3' deep and several feet wider than the foundation, fill with 1" crushed limestone 1 foot at a time. Fill with ag lime and repeat. (Ag lime is just fine limestone, and will almost make concrete out of the limestone).
Wow, a lot of good input. Thank you. They say basements are low cost square footage, maybe I should bite the bullet and incorporate a basement. I hate the thought of digging it out to simply fill it again. The basement could be open on the back side and could have a garage door installed. Who couldn't use more garage area? Decisions, Decisions.........
/ How long for dirt to settle? #7
In Ohio we used clay & misc material to fill in a old basement, that was mid 80's. it is still settling some each year it takes a couple truck loads to KEEP it level. that is the problem depending on the material it may not settle much for years then a good freeze and down it goes ... I wouldn't want that UNDER my home at all... just my 2 cents worth. compaction is in 6" lifts using native material and or less... this spot had some left over debris from the destruction (from fire) which was left on site and burried to get rid of it. that wood/leftovers was or is what is setteling the most for sure as it rots. in the last ten yrs I bet we have put in 3 or 4 feet of fill into the old hole. it is down about 12" in the center again after about 4 years of setting since the last fill..
Mark M
/ How long for dirt to settle? #8
I had a slope that had an unknown pedigree for compaction. I had to have it dug out and put back in a foot at a time. Here is the Cat excavator with the poker it took to get it compacted at 95% (required, it came out at 98%). This is decomposed granite here in California. I dug a trench for a water line on the back hill in native soil and after I filled in the trench, it settled an uneven 2 to 3 inches all along the trench. You'd think undisturbed soil would be fairly compacted, but here it wasn't.
That would be a great Chistmas present. Ask your wife if I can have one too....... /forums/images/graemlins/cool.gif
After all the great input, I went out and placed some stakes in the yard to see where I might want my new building. It is possible to have the footprint of the new building to be outside of the old basement. So it appears I have two safe choices 1) have a crawl space or 2) dig a basement under the new building. If I go with a crawl space and I place my footing within a foot or two of the old basement fill, does anyone see a problem with that? Footing would probably be 4 feet below ground. Just curious. Thanks
/ How long for dirt to settle? #11
snooks it probably would be OK, BUT there is always the chance of the old basement moving some if the footing is aginst it and pushing down it is forcing the old walls IN or away from the new footing. I would go with full basement it would only be a few grand more than the 4' crawl space... then you have storage and good access under the new home for plumbing, HVAC ect. not to mention a place to hide when the big tornados (or in-laws) come along! /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
MarkM
Yeah, I think your right. I have laid stakes and looked at this thing from all angles. The building is actually going to be an accounting office. To get it wide enough so as to not run into problems with the unstable ground, I find it is messing up my floor plans. I end up right back where I started and that is to include a basement. Of coarse the question then becomes do I want poured walls, prefab walls, block walls, ect..... I have a client that does the prefab walls and they look pretty nice. Probably in the long run that would be the way to go. They are designed in such a way they can be insulated and have cavities for wiring and the like. This would potentially allow for further expansion and/or record storage.
/ How long for dirt to settle? #13
Snooks,
The new foundation will exert forces that may influence the existing foundation wall. With the backfill behind the existing wall not compacted to structural compaction requirements (although I realize you did compact the fill with your tractor, structural requirements are very stringent requiring a very high level of compaction, 95 to 98% compaction) this may cause problems with the new foundation down the road.
General guidelines to try to avoid this are as follows:
The bottom edge of the new foundation needs to be as far away from the existing foundation wall as it is above the top of the old foundation. In other words, if the bottom of the new foundation is 4 feet above existing footing, the edge of the new foundation needs to be four feet from the existing wall.
…Derek
Thanks for the information. If I dig out the dirt from the old basement, which was about 6 feet in the ground, and make the new basement a little deeper I think I should be fine. Since it is an office building, I want the first floor very close to ground level so I don't have to have a long wheel chair ramp. Thanks for all the input, it has allowed me to think this thing through. Basement it will be.....
/ How long for dirt to settle? #15
I am not sure what prefab stuff you have been looking at but we just built our new house with Superior Wall System, the original stuff not the new higher insulation one. We have only been in the house for a year but I like it so much better than block wall. The wood furring strips on the walls make it easy to hang stuff like shelving.
Eric
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2011 Kenworth T800 Truck T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2011 Kenworth T800...
1979 MERIT FUEL TRANSPORT TRAILER (A67714)
1979 MERIT FUEL...
HONDA Plate Compactor (A64557)
HONDA Plate...
213087 (A64276)
213087 (A64276)
Unused 2023 Paladin Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2023...
