How long do you glow your Deutz intake heating elements?
   / How long do you glow your Deutz intake heating elements? #1
m5040
Veteran Member
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Just wondering what everyone (that has the heaters) uses for a time to energize the heater on a glow cycle? Yesterday I needed to use 2 tractors it was 30 degs. One started easily after a 10 sec glow. The other tractor which has the newer model engine, but has been sitting for a month, had a surprisingly hard time to start. I glowed it up to 12 secs and than left it on while it cranked for maybe 30 more seconds (the airflow should cool it down). The fuel tank was down to 1/4, maybe it was slightly airbound?
Some IDI engine brands with prechamber glow plugs are self regulating, could that be too much to ask?
   / How long do you glow your Deutz intake heating elements? #2
I usually run glow plugs for no more than 5 seconds on my kubotas and yanmar. Terry told me I shouldn’t even need glow plugs in middle Tennessee.
   / How long do you glow your Deutz intake heating elements? #3
FWIW: I run the Deutz glow plugs 10-20 seconds depending on how cold it is. "Warm" being 40F, and "Cold" being 34F. Unlike IDI engines with glow plugs in the combustion chamber, I haven't noticed any benefit to running the glow plugs after the engine catches.
The glow plugs definitely help, but the biggest help for me at my temperatures was upgrading the starter to the higher power starter. (1.5kW to 2.3kW?)
I do give the PT a chance to warm up the hydraulic oil when it is cold, or the pedal response is too slow for my comfort. Lots of obstacles and drop offs around here.
All the best,
Peter
   / How long do you glow your Deutz intake heating elements? #4
I leave my heat gun on the intake on low, aim the salamander at the oil tank and go have a couple cups of coffee. By the time I put my boots on, she fires right up!
   / How long do you glow your Deutz intake heating elements? #5
FWIW, glow plugs and intake heaters are very different and require different handling.
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
