How long can cylinder rods remain exposed to the elements before they should be coated with something?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #21
Move to the desert! Nothing rusts out here. I had left over rebar from my house build that layed on the ground for 10 years before it developed light surface rust. ;)
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #22
That's why they park all them planes out there.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #23
Our tractor (and all its attachments) sat out in the open the first 2 years we had it (its 6 years old now). We bought empty land and there was nothing but some trees on it, so I parked it behind one of the big fir's so it wasn't easily seen from the nearest road.
My experience, and I'm in the Pacific Northwest, is tractors are made to take the elements. I did tarp the attachments, but as others mentioned, that can cause its own issues... like providing a nice dry place for mice to make a home as I found out. I had zero issues with the slide rods and such being exposed and did nothing special to them otherwise.
If I did it over again, I'd make some cheap lean-to's with pallets and tarps so while things would stay drier, I wouldn't be providing space for varmints.
Make sure to zerk your fittings before storing, and rezerk when your ready for use again.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #24
I believe those rods are stainless steel so they won’t rust very easily
They are chrome plated which has become thinner, cheaper and less effective over time. I've never seen or heard of a stainless steel hydraulic cylinder rod.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #25
My things are under cover but I spray with white lithium grease when I put loaders away for any length of time or over winter. It sticks tight and I've never had a speck of rust. I'll bet it would work well outside.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #26
I am always surprised that farm wreckers, never bother to protect cylinders. For the little it takes and the immense value it adds to used equipment if the cylinders are in good shape.
This kind of long term outdoor storage, or if the cylinder was starting to rust, would be the only time I would even think about it.
Actually, if parked outside, hoses are a far bigger concern if you ask me. Have a Big Dump Trailer that's been sitting out maybe ten years and the (then new) hoses look they they have been in a fire! Had "meant" to protect them with sleeving
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #27
Something like ACF50 spray would protect without being too sticky. Or lateral thinking, could you disconnect the eyes so that the cylinders could all be retracted?
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #28
Or take them off completely and keep them inside.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #29
Never stainless, unless your equipment costs $millions. They are chromed steel rods. The price of the cylinder normally determines the quality of the chrome plating or the number of plating layers. Any chroming can be damaged or break down so that there is exposure by the underlying steel. The issue is how long before that happens, which is the purpose of the original question.
   / How long can cylinder rods remain exposed to the elements before they should be coated with something? #30
Really? Is that picture of your tractor? Would you ever consider taking off all of the cylinders on your tractor?
John Deere 3025E (A53317)
John Deere 3025E...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
Honda Em3800SX Generator (A55851)
Honda Em3800SX...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2011 Chevrolet Tahoe SUV (A55853)
2011 Chevrolet...
