How long before Compact Diesels are obsolete?
   / How long before Compact Diesels are obsolete? #201
Electric vehicle success is going to depend largely on solar affordability. I think it has been coming down but haven't done any research to support that notion. I have seen a large solar field just east of me. The panels are on automated pivots that follow the sun. I'm talking several hundred acres as far as the eye can see.
Most of us have some solar panels in use. I have been pleased with my limited use of panels to keep batteries charged.
The problem with solar on equipment that operates during the day is the need for a separate battery bank. The solar panels will need to charge an idle battery bank during the day to then transfer that charge to the batteries that are parked at night
We avoid that with "Grid Tie" where available. The Solar PV is tied the Grid, and the Battery Charger is also tied to the grid. The grid gets the valuable Day Time Peak Use supply from the Solar PV, and then we charge the batteries when it is handy for us. Win-Win for most local grids.
   / How long before Compact Diesels are obsolete? #202
Rural Michigan? Grew up there. A smaller or reducing local economy make for difficult budgets. No one wants to invest in a risky or potential shrinking market. In much of the US we use a "Service Life" model. Most components have a 25 to 50 year Service Life. So that means we will replace up to 4% per year (for 25 year life equipment) or down to 2% (for 50 year life equipment) any given year. Add on some growth (again, for growing local economies) of 1 to 2% per year -- and we are replacing or expanding around 5% every year.
So for now, in Texas -- folks just ask about chargers, and we are happy to put in new transformers, lines, etc., as needed. Happy to sell the extra electricity to a new customer. Locally that means the grid is continually renewing all around US. But again, that is an expanding market and economy.
Sort of ironic on the reducing or shrinking Michigan model -- if Michigan had embraced EVs, upfront, the whole region would be leading US. Instead they half-assed the Volt, and then the dealers backstabbed the whole thing.
I see Texas did well this past winter with their electric grid :ROFLMAO: Search Eddie walker post(rural living) on how long his neutral primary line has been laying on the ground UNFIXED..Little food for thought if you think the NEW GREEN deal is the answer you my friend are WRONG..Been in this business for well over 40 years..
   / How long before Compact Diesels are obsolete? #203
Here is what we (should) have learnted regarding the Texas Snowpocalypse:
1. Good Regulation = Good Results.
2. Bad Regulation = Bad Results.
3. No Regulation (Texas) = Stupid. ;)
but as far as 40 years, you may want to consider that trying to drive forward while looking in the rear-view mirror does not always work the best.
You may (or may not) like some of this. Maybe try the first 10 minutes or so.
Good stuff for opening minds that can still be opened >>>
   / How long before Compact Diesels are obsolete? #204
I see a lot of the discussion on here about batteries, batteries, batteries.
That may not be the full path ahead.
Anyone look this over? Any thoughts?
   / How long before Compact Diesels are obsolete? #205
What is your back ground in the electric gird? Just curious
   / How long before Compact Diesels are obsolete? #206
Worked all three sides on Engineering side -- EPC Contractor, Engineer of Record, and Owner's Rep. -- Technical side -- Texas Master and J-Man.
Did some time as a Site Engineer for the Big Generator -- TXU, and later as a Staff Engineer for them for compliance, and then a bunch of Substation Design and Build since. My preference would some HVDC, but we do not have a lot of that going on.
You were correct -- the Eddie Walker story is out there. I had gotten notices that Oncor (that is our Poles and Wires for the Public Utilities area -- non-Co-op areas) was looking to drag a bunch of Engineers back in for local assignments. My guess is Eddie's area may be "missing" an Engineer?
   / How long before Compact Diesels are obsolete? #207
Why do you need a engineer for a downed power line ?? You need a electric lineman to fix it..
   / How long before Compact Diesels are obsolete? #208
In a sane world, yes.
But in this case -- to get the work assigned and make sure it happens.
   / How long before Compact Diesels are obsolete? #209
the reason nothing gets done out in the field is due to the engineers. i was just at a job for a friend of mine getting power to his new house. line crew was there along with the engineer. the engineer is running off of these tangents telling us how we cant run power the way were planning, telling us how to do it the proper way. after 30 minutes of back and forth he leaves. the foreman comes over to us and tells us hell put it in the way we wanted to. there was no problem with that method.
   / How long before Compact Diesels are obsolete? #210
hahaha ahhhh. I feel your pain.
Some days, I help cause it.
Anymore, I try to do like the Penguins in the kid's movie Madagascar.
"Smile and Wave, just Smile and Wave."
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
