How long befor it goes "POP"
/ How long befor it goes "POP" #1
davitk
Platinum Member
South Central Wisconsin
OK, if water is 8.3 pound per gallon, and my watering can hold 275 gallons....
:eek:
I had better get off this dern computer and turn off the hose :D
/ How long befor it goes "POP" #3
What did your "watering can" originally hold in it? Would it be safe to hold drinking water?
Wayne County Hose said:
Favre for Quarterback!
:rolleyes: That man needs a hobby.
Isopropyl alcohol. Available at most major airports - check Craig's List for resellers, mine was 75.00 but you could probably do better.
/ How long befor it goes "POP" #10
:eek:
Best not fill it that is a bit over 2000 lbs. not sure you can pull it but would be interesting to see if it could:D
I was feeling stupid this morning so for fun I did just that :p The trailer tires are about 30 years old and rated for 590#'s each, they held as did that rickety old trailer. Mower pulled it OK, even up a slight incline, so all was fine until I opened the valve..... There is an 8" diameter fill cap on the top with a rubber gasket but no vent, I caught it in time before it completely turned inside out :eek: and pounded it back into shape with a rubber mallet. Tomorrow's another day......:D
/ How long befor it goes "POP" #12
In my area of the Southwest, alot of people haul water from water supply points. (about a quarter for 85 gallons). These are sold all around the area as Potable water tanks.
I have one that I take with me to concrete pours if there is no well on site.
