How hot is too hot for hydraulics?
   / How hot is too hot for hydraulics? #1
JeepHead
The hills of Southern Indiana
Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
Right after I purchased my Kubota, I installed a two spool valve from Summit to control top/tilt. I have noticed that the valve always gets very hot, not hot enough to blister you but definitely very hot. I know some heat is normal under heavy use but when do you know there is an issue and need to investigate?
   / How hot is too hot for hydraulics? #2
Can you give us more details on how is this valve connected to the rest of the system?
   / How hot is too hot for hydraulics? #3
Normal hydraulic oil temperature should be in the 140 - 180 degrees F depending on how hard you are working the hydraulics.
Recommended max oil temp is usually 220 - 230 F since hotter than that starts effecting seal materials.
PB from loader to P on the P40G
PB Sleeve in the N port of valve
N to the port on the hydraulic block where the loader BY had been.
T Port on the p40G to a tee on the tank vent.
I would say that I am within that range. Thanks!
   / How hot is too hot for hydraulics? #6
I forget the actual temperature, but somewhere around 120 degrees F is sensed as too hot to touch.
I checked my transmission case with an infrared temp tool, and get around 180 when working the machine.
   / How hot is too hot for hydraulics? #7
The number I have consistently heard for too hot to touch is 130, not 120. As in you cannot hold your hand on a 130F surface without either getting a burn or just pulling away. Either way, even 120 is not going to be pleasant.
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
Toro Groundsmaster...
Rolling Drain Pan, 44" x 27" w/Pump to Drain (A59076)
Rolling Drain Pan...
2013 Chevrolet Silverado 3500HD 4x4 Crew Cab Flatbed Truck (A55973)
2013 Chevrolet...
