Ballast How heavy a weight box do you need?
/ How heavy a weight box do you need? #1
Kioti Tom
Industry, Pa- - 5 mi. north of Ohio River
Kioti DS4510, Ford '48 8N, Ford '53 Jubilee, Power King 1614
If you are wondering how heavy a weight box you need for your Kioti I finally found where I has seen it before. Go to the Kioti USA webpage, then click on products, then click on attachments, then click on FEL. You then click on your model loader. The list of loader specifications has a line item in there that gives the weight required.
Hope this helps...
Tom
/ How heavy a weight box do you need? #2
Good information to know.
Nothing more unnerving than having the rear end of a tractor lifting or floating because you don't have enough ballast.
Even with loaded tires it doesn't take much on the front end to raise the back end.
