How Hard to Convert?
/ How Hard to Convert? #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I have a 15 year old LG 36 hp 4WD loader tractor with < 100 hours on it.
How hard would it be to convert the loader to a SSQA?
Is this kind of conversion common and cost efficient?
TIA
Yooper Dave
/ How Hard to Convert? #2
What are your welding/fabrication resources?
Many threads on here of conversions, seems very doable. Only cost "efficient" if you swap FEL attachments.
/ How Hard to Convert? #3
With tractor use at <7 engine hours per year, why bother?
It will take more than seven hours to assemble material and make the change ~~~~~then you need to convert the FEL attachments you have.
/ How Hard to Convert? #4
I purchased an adapter at a junk yard, and adapted it to my tractor,,,
I did do the adapter conversion in CAD before I cut any steel,, that helped,,,
I moved to a different house and now have use for a tractor.
Your conversion exceeded my expectations. Thanks for sharing. What CAD software did you use?
Auto CAD is my software of choice.
/ How Hard to Convert? #8
I learned 3D solid modeling on CADkey, and still use it for stuff like this.
/ How Hard to Convert? #10
I am not familiar with the LG tractors, so many after market companies make adapters to SSQA for many manufacturers, they are not horribly expensive I would try to find one for yours OR try to modify one since it will likely be close to your machine in some regard.
/ How Hard to Convert? #11
I made a SSQA from scratch for my B21. Because there were no commercial options. In looking for commercial options, there are 4 main things to consider. First is loader pin size, the QA has to match what you have. Second is distance between the two loader pins. QA has to match or be very close. If not, curl and dump will be different and maybe unworkable. Third is width. Needs to be close. You can use washers or spacers to make up the difference. The fourth is rollback angle. You need a QA that will allow required rollback for bucket, or forks, as well as required dump angle.
/ How Hard to Convert? #12
Converting is not difficult. Titan is the least expensive but the existing brackets just be cut free of an existing bucket.
Hayspear, Washburn offers a conversion that includes adjustable brackets, simplified conversion. See screenshot.
Tomahawk offers the least expensive adapters for the implements (adapter plates)
/ How Hard to Convert? #13
if you don't do a ton of swaps this is what I did plus my 1620 doesn't have a ton of lift capacityIMG_1533.jpgIMG_1534.jpgIMG_1536.jpg
/ How Hard to Convert? #14
My 1620 Has respectable lift capacity, has a koyker loader, switch between bucket and forks regularly. Guessing capacity at lift pins is about 1000 lbs.
/ How Hard to Convert? #16
her is how i built mine on my homemade tractor,now i can build allot of attachments,is it worth it,yes so much faster to change out attachments, now in the process of building a ripper tooth,
sorry for the bad cell pics,last photo ,getting ready to make attachment brackets, ill have to get more pics of the bucket bracket,cell camara quit, Godbless
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2014 MACK GRANITE (A65643)
2014 MACK GRANITE...
Skeleton Backing Plate (A62679)
Skeleton Backing...
