How hard is it to learn to use a rental mini-excavator?
   / How hard is it to learn to use a rental mini-excavator? #11
4 days including taxes, insurance, fuel and delivery? For what size?
Yes, $550 total with fuel and delivery/ pickup. No idea the size, its in the pictures above. I told them what I intended to use it for and they sized it appropriately.
   / How hard is it to learn to use a rental mini-excavator? #12
That’s a really good deal. There’s 3 options for rentals in my area. Lowes has a Cat 302.7 which is smaller than the one you rented for $329 for 24 hours or $987 for a week. Neither price includes tax or delivery. The other 2 places don’t have the rates published on their website but they’re comparable.
   / How hard is it to learn to use a rental mini-excavator? #13
When I was looking at the local equipment rental places they were much higher. I happened to be at the dealer I bought my tractor from and I mentioned wishing I had a mini x and he said they rented them out, had no idea they did that. He did cut me a break since it was a holiday weekend and they didn't need it back right away but it was still going to be about $800 for 4 days.
   / How hard is it to learn to use a rental mini-excavator? #14
My dealer rents them as well but they require you to have your own insurance which makes them pretty unappealing to a homeowner.
   / How hard is it to learn to use a rental mini-excavator? #15
I wonder if its a state requirement or something they want? I didn't have to have anything like that.
   / How hard is it to learn to use a rental mini-excavator? #16
The learning curve is very short, especially if you’re already familiar with operating equipment (in terms of being careful, respecting the power of hydraulics, etc).
I actually bought a used large one (Hitach EX-60UR) (about 6.5 tons weight) around 2008, used it for about ten years, then sold it for pretty much what I paid for it.
Depending on how large your stumps are, you generally will want the largest excavator that you can afford. Makes it easier if there is a thumb on the bucket, especially if there are large rocks around the stumps to deal with.
Just a suggestion - look on Craigslist or somewhere for someone who does that type if work. Might be less expensive and less of a headache to just hire it out if this just a one time thing for you.
   / How hard is it to learn to use a rental mini-excavator? #18
Renting isn’t their business model. They don’t even have a sign up that they do it. I figured they decided it was easier to pass the responsibility on to the customer instead of getting the correct rental insurance.
   / How hard is it to learn to use a rental mini-excavator? #19
Not hard at all.
Have the rental people give you a quick run through.
   / How hard is it to learn to use a rental mini-excavator? #20
I'm considering renting a mini-excavator to dig about 10 stumps in the 12 to 24" range. My question is, how steep is the learning curve for a mini-excavator for someone who has lots of hydraulic tractor experience? Can I reasonably expect to dig 10 stumps in a day starting with no mini-excavator experience?
Depends on soil type and your aptitude for such things. Both are huge variables. That said, a rental mini small enough to tow with a 3/4 or one ton pickup is definitely not the right tool to be pulling 24 inch stumps, unless the roots are already rotted. Consider renting a big stump grinder or hiring someone to grind the stumps. It'll probably be similar money or cheaper and the end result will be much more satisfactory. I owned a tree service in Ohio for 20 years. With the stump grinder that I had, grinding 10 12-24" stumps would have taken about one to two hours or so, depending on tree species and root flare and assuming fairly easy access.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
1980 PULLMAN DRYVAN (A58214)
1980 PULLMAN...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
