How far should it stick out
/ How far should it stick out #4
BXMMCC
I added a much heavier rubber cutting edge to my 6 1/2' Curtis blade. I originally had it sticking about 5". The rubber rolled back almost 45 degrees. I then changed the mounting so that rubber stuck out about 2". By mounting the rubber in front of the steel cutting edge. I'm happy with this setup. /forums/images/graemlins/smile.gif
Here is a link to the thread with pictures that TresCrows started on his plastic edge. Click Here
/ How far should it stick out #5
I find that the rubber edge sticking out 2" from the backing plate is good. Any more than that and it will roll/bend under pressure. I was worried that it would wear down fast, but there is very little wear after a full season of plowing a couple paved and several gravel drives.
Mark
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
