Mowing How does your BX mower hang?
/ How does your BX mower hang? #1
Speedy7
North East MA
Kubota BX23
Thought that would get your attention!
But seriously, when my mower (60" MM on BX23) is at it's fully retracted setting and I go over bumpy ground, it kinda rattles up and down a bit on one side. Is this normal, or should I look to adjust it? It came from the dealer with the cutting height settings pretty much matching the knob and cuts fine and evenly.
Just finished my first weekend with the new BX23. Not quite the bear my old Teramite backhoe was, but adequate for what I need it for now. Attached is a picture of it in it's new home. Just about fits in the 16'x12' shed, but have to rest the bucket on the potting table to close the door. When I dismount the mower for winter, I expect that I will have to store that in the garage, so next years project is going to be a 6' x 16' extension to the shed!
SP
/ How does your BX mower hang? #2
Hey mine hangs a little loose on the left side when up and wobbles a bit.But it works fine.Sound's a little funny for a tractor site you got to admit.Keep the shinny side up.Red
/ How does your BX mower hang? #3
Mine bangs away pretty good when I travel over bumpy ground. It doesn't take long to remove and turning the scalp wheels 90 degrees makes it a joy to just zip out from under the tractor. I always remove my deck if I'm going to be doing other work with the tractor. She sure looks pretty all new and shiny, huh?
/ How does your BX mower hang? #4
Speedy7,
My BX22 does the same thing. Gets annoying after a while. If yours cuts OK, as mine does, I wouldn't try adjusting anything. You might want to check your adjustments just to make sure everything is OK. I checked mine and found nothing wrong.
Jeff
/ How does your BX mower hang? #5
Catchy title /forums/images/graemlins/grin.gif
So since I looked I'll go on ahead give my $0.02. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
One of the adjustments for the MMM is to adj the lift linkage to where the MMM stops 1/4" shy of hitting the right side stop at it's maximum lift point. It's covered pretty well in the MMM owners manual. This is where it's hitting.
I've been pondering on securing a small rubber pad at both points on the MMM where it contacts the frame stops but I've been living with it since day one and haven't gotten past the pondering stage, I just slow down. Perhaps it'll make a good winter project.
Have you discovered how easy it is to take off with the parking brake set yet? The lugging engine is your 1st indicator /forums/images/graemlins/grin.gif
Volfandt
Three responses within 20 minutes! Wow, this board is awesome!
</font><font color="blue" class="small">( Have you discovered how easy it is to take off with the parking brake set yet? The lugging engine is your 1st indicator /forums/images/graemlins/grin.gif )</font>
You know, maybe it's because I kept reading about it here before I got mine, but so far, it has not happened to me. I tend to start off slow when I first get going anyway, and then increase the throttle, so it's pretty obvious if the brake is on.
This weekend alone, I must have had the FEL and BH off and on at least 3 times, so it's a testament to how easy it is. I haven't taken the mower deck off yet, and I understand that is not as simple, what with the PTO coupling and all. I plan on building a dolly for removal and another one for vertical storage.
SP
/ How does your BX mower hang? #8
The banging is your rear links bouncing off the frame stop. If you lower the deck a little bit (1/2") it stops.
</font><font color="blue" class="small">( I haven't taken the mower deck off yet, and I understand that is not as simple, what with the PTO coupling and all.
SP )</font>
Removing the MMM scares me less than the BH or FEL. The engine is off and nothing has very far to fall. /forums/images/graemlins/blush.gif
Russell in Texas
/ How does your BX mower hang? #9
</font><font color="blue" class="small">( and I understand that is not as simple, what with the PTO coupling and all. I plan on building a dolly for removal and another one for vertical storage.
SP
)</font>
Very easy once you have done it a few times, just do it. /forums/images/graemlins/grin.gif
Also pick up a set of stands for $89 to store the mmm at this company, they work great, and Larry is a just a great guy to do business with.
web page
/ How does your BX mower hang? #10
Agree, R&R'ing the MMM isn't as bad as many say.
One trick I use is to drop the MMM a few inches inorder to spin the left side rear caster, the rest are very easy to spin.
The locking collar makes the PTO shaft easy to connect/disconnect.
I have a set of those moweraxles and they work very well for stowing and serviceing the MMM.
Volfandt
Well, since we're having an indian summer Halloween here in the North East, I decided to take a break and practice dismounting my mower for the first time.
Dismounting was easy and straightforward, but I had a little bit of trouble re-installing the lift links when I went to reinstall it. Guess practice will improve it, but for some reason I had a devil of a time lining up the pins into the flange. Other than that, the only other slightly ackward part was reseating the PTO coupling, since you have to get down and under to do it.
You can get dirty doing it compared to the FEL and BH, but still tool-less.
SP
/ How does your BX mower hang? #12
Concerning the MMM rattling when raised for transport, try turning the dial that adjusts the cut of the mower to the "TOP" position, and then lower the mower. The MMM rides securely there.
Will
/ How does your BX mower hang? #13
If you are not using the mower I find it is best to raise it all the way up, turn the height dial to "top" then lower it down to rest on the stops. This is what keeps the mower deck up when you are using the 3PH and keeps teh lift arms off teh ground when you have the deck off. This little bit of drop gets the deck down so the top of the deck doesn't bang against the upper limit stop on the tractor. SHould qiet things down some.
/ How does your BX mower hang? #14
I had mine for about a year before I discovered the pins that will hold the latch pins open for ease of alignment.
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
2019 TAKEUCHI TL12V2 SKID STEER (A65053)
2019 TAKEUCHI...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
