How Does This Work? Voodoo Engineering?
   / How Does This Work? Voodoo Engineering? #21
There's no voodoo engineering going on, you guys just don't have your facts straight. Absolutely zero chance that Kubota is going to lie about their engine performance.
(there are several different versions of their v1505 engine, but it should be this 30.8 HP one in the LX3310)
Y
i misread the tractorgear website , it states torque 84.6 at 2000rpm not 77ftlbs
   / How Does This Work? Voodoo Engineering? #22
Well thats odd. On the Kubota spec sheet, they list the engine as the V1505-CR-TE5-D36R1, which is the turbocharged version that makes 44 HP. But the lx3310 should only has 30.8 HP. Maybe they did confuse something after all.
Does the LX3310 have a turbo?
The 44hp is at 3000rpm, the LX3310 has a rated rpm of 2500 which is part of the reduction, I'd guess the remainder of the lowered HP is through a milder tune to hit a target output/increase longevity. Kind of like they do with the reduced power on a lot of cab and chassis trucks compared to their pickup counterparts.
   / How Does This Work? Voodoo Engineering? #23
Ok so it looks like yes, the lx3310 does have the turbo V1505. Likely de-rated some vs the industrial application engine, indeed. Thats a nice engine....
   / How Does This Work? Voodoo Engineering? #24
I think being lost is the use of the tractor. Regardless of the peak Hp, many people use the tractor PTO. That limits the engine rpm to the number that produces 540 PTO rpm. The designers will have selected the gearing to best use the engine at 540 PTO rpm. Compare ratings at that engine speed.
   / How Does This Work? Voodoo Engineering? #25
According to this calculator:
Calculate horsepower from torque:
Deere: 77.2 ft-lbs at 2500 rpm is: 36.7 Hp (Deere says 37.2Hp/30Hp (PTO))
Kubota: 77.7 ft-lbs at 2500 rpm is: 37 Hp (Kubota says 30.8Hp/27Hp(PTO))
Calculate torque from horsepower (assuming listed Hp is at 2500rpm….but is it?):
Deere: 37.2 Hp at 2500 rpm is: 78.1 ft-lbs
Deere (PTO): 30 Hp at 2500rpm is: 63 ft-lbs
Kubota: 30.8 Hp at 2500 rpm: 64.7 ft-lbs
Kubota (PTO): 27 Hp at 2500 rpm: 56.7 ft-lbs
Interpret away…
I’m confused by how Kubota gets 77.7 ft-lbs at 2500 rpms out of a 30.8 hp engine when math says it takes 37Hp?
Perhaps if 2075 rpms was engine speed for 540 rpm (PTO) and it still produced 77.8 ft-lbs (assuming a flat torque curve) that would equal 30.8 hp, but would you call it a 30.8Hp engine if it produces 37 Hp at 2500rpm?
   / How Does This Work? Voodoo Engineering? #26
Without a complete torque and hp curve from the manufacture all the calculations are just playing with numbers.
Many tractor engines do not develop maximum torque at their rated rpm,
quite often the torque peak will be several hundred rpm below the hp peak.
Many times 540 rpm PTO engine speed will be below the hp peak and above the torque peak.
And don't forget the value of displacement on torque curves.
   / How Does This Work? Voodoo Engineering? #27
Agree Lou. It seems that their horsepower numbers aren’t tied to (qualified by) a particular rpm.
My understanding is Horsepower numbers are often from a “bench test”, done without standard intake, exhaust, pollution (etc..?) systems that engine has when installed on tractor. That is, differences between engine and PTO horsepowers are not just losses in transmission.
   / How Does This Work? Voodoo Engineering? #29
I was comparing the specs between a John Deere 3038E and a Kubota LX3310 and I'm not understanding how these numbers work. If anybody has any ideas please share them.
John Deere 3038E:
Engine Torque at rated speed: 77.2 ft-lbs
Rated Speed/RPM: 2500
Engine horsepower: 37.2
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
Engine Torque at rated speed: 77.7 ft-lbs
Engine horsepower: 30.8
PTO horsepower: 27
Weight: 1,918 lbs
What is it to not understand? The numbers are right there.
   / How Does This Work? Voodoo Engineering? #30
Nobody has gone down this road yet but these are 2 completely different frame sized machines. If you compare like for like the l3301 will clobber the lx3310 all day long. Roughly the same ponies but many more differences. I just had trees cut down and the tree guy brought his lx3310 with his wicked 55 for clean up. I had my l3901 and wicked 55 out and he ran both. Horse power aside he flat out told me my machine would out work his all day long.
2003 Big Tex 10PI...
Nissan Forklift (A55973)
Nissan Forklift...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
John Deere 5103 (A53317)
John Deere 5103...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
