How Does This Work? Voodoo Engineering?
   / How Does This Work? Voodoo Engineering? #1
Cahaba Valley Farm
Veteran Member
Somewhere Alabama
1980 Ford 3600
I was comparing the specs between a John Deere 3038E and a Kubota LX3310 and I'm not understanding how these numbers work. If anybody has any ideas please share them.
John Deere 3038E:
Engine Torque at rated speed: 77.2 ft-lbs
Rated Speed/RPM: 2500
Engine horsepower: 37.2
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
Engine Torque at rated speed: 77.7 ft-lbs
Engine horsepower: 30.8
PTO horsepower: 27
Weight: 1,918 lbs
   / How Does This Work? Voodoo Engineering? #2
John Deere 3038E:
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
PTO horsepower: 27
Weight: 1,918 lbs
The JD's torque is 88.5lb-ft according to Tractor Data
But 77.2 according to JD themselves, so... 🤷
   / How Does This Work? Voodoo Engineering? #4
You need rpm and torque to establish HP. More RPM at the same torque equals more hp.
   / How Does This Work? Voodoo Engineering? #5
the formula is:
HP = Torque x RPM / 5252
For torque in lbf-ft. So you can have torque and hp peaks at different engine rpm depending on specs snd tuning.
why are you looking at sub 2000 pound tractors now? After all that ranting in your other thread, lol.
   / How Does This Work? Voodoo Engineering? #6
Here is the derivation of this formula.
LINK
   / How Does This Work? Voodoo Engineering? #7
John Deere 3038E:
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
PTO horsepower: 27
Weight: 1,918 lbs
How they work? What do u mean?
Ideas? About what
Your signature phrase there suggest you know what torque is. So what are you asking?
  • Good Post
Reactions: JWR
   / How Does This Work? Voodoo Engineering? #8
If “rated speed” is engine rpms when the PTO is turning at a standardized 540 rpm that most attachments operate at, it means the Deere’s engine is turning at a faster rpm to get the 540 rpm at the PTO.
Like others say:
(Horse) power = Torque x RPM
(don’t worry about the other numbers in the formula. They’re just conversion factors for keeping the units (Hp, foot-pounds, minutes, seconds, etc..) straight.
So if 2 tractors have the same torque, but one outputs more horsepower, it’s engine rpms must be higher at “rated speed”.
“Rated speed” is the undefined, confusing term in the above info.
Example your weedwacker turning at 12,000 rpm may have the same horsepower rating as an electric motor turning 1200 rpms, but it’s going to have 1/10th the torque.
   / How Does This Work? Voodoo Engineering? #9
What part of it are you having problems with?
   / How Does This Work? Voodoo Engineering? #10
John Deere 3038E:
PTO horsepower: 30
Weight: 2,222 lbs
Kubota LX3310:
PTO horsepower: 27
Weight: 1,918 lbs
I think the problem is that you may be expecting that JD's "rated speed" is the same as Kubota's. It may be that both use the same RPM for rated speed, but it doesn't have to be the same and if it was it would be a coincidence.
In this case it looks to me like JD's engine is set up to produce their torque figure at a rated speed that is slightly higher than the Kubota's. There could be as much as a couple hundred RPMs difference.
If so, and the torque is the same, then when we calculate HP using HP = torque times RPM we get different HP.
Does that help?
rScotty
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
