How does sawdust get into a sealed electric motor?
   / How does sawdust get into a sealed electric motor?
Won’t be working on this for awhile I’ve been admitted with Covid 🙁
Like @DarkBlack I'd bet it came through the junction box.
As it is an induction motor, it is only going to possibly going to arc/spark when the windings fail, but I do think @MAX-24-Dean makes a great point about why it is worth cleaning the housing out and improving the sealing. I've seen the results of motor induced explosions and the results certainly make an impression. :eek: I would replace the felt seals on the shaft (just a guess. Many older motors had them. Did it have any / is there room for them?), sealing it up with some sealant when you reassemble the housing, and I would switch to water/dust tight cable glands / clamps.
Let us know how the saw is after the overhaul!
All the best,
Peter
No felt seals on shaft & bearings are sealed. Sawdust must have entered thru the junction box.
My unisaw mod is finished!
The tilt/raise mechanism is cleaned & lubricated and operates very smooth. The gearing shows no wear despite its age so it may not have that many hours on it.
The re-wiring went smoothly & added an outlet for the power feed to plug into. New belts were installed & a closure plate made for a 4” dust collection port.
I cannot attach photos it says the file does not have an allowed extension.
Photos to follow hopefully 🤞
Hopefully the photos are attached.
Thank you!
I certainly enjoy having space to tinker & do woodworking when the urge hits me.
Yesterday I was running oak thru the table saw using power feed and the saw did not disappoint me.
90cummins
   / How does sawdust get into a sealed electric motor? #17
Thank you!
90cummins
That's great news!
   / How does sawdust get into a sealed electric motor? #18
This would be a great science fair project to find out how sawdust gets into a motor,
Good one👍
2013 Club Car Turf Carryall (A50121)
2013 Club Car Turf...
(4) Gladiator 12-16.5 Skid Steer Tires (A50121)
(4) Gladiator...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Vermeer 840 Discbine (A50774)
Vermeer 840...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
