How does sawdust get into a sealed electric motor?
   / How does sawdust get into a sealed electric motor?
Won’t be working on this for awhile I’ve been admitted with Covid 🙁
Like @DarkBlack I'd bet it came through the junction box.
As it is an induction motor, it is only going to possibly going to arc/spark when the windings fail, but I do think @MAX-24-Dean makes a great point about why it is worth cleaning the housing out and improving the sealing. I've seen the results of motor induced explosions and the results certainly make an impression. :eek: I would replace the felt seals on the shaft (just a guess. Many older motors had them. Did it have any / is there room for them?), sealing it up with some sealant when you reassemble the housing, and I would switch to water/dust tight cable glands / clamps.
Let us know how the saw is after the overhaul!
All the best,
Peter
No felt seals on shaft & bearings are sealed. Sawdust must have entered thru the junction box.
My unisaw mod is finished!
The tilt/raise mechanism is cleaned & lubricated and operates very smooth. The gearing shows no wear despite its age so it may not have that many hours on it.
The re-wiring went smoothly & added an outlet for the power feed to plug into. New belts were installed & a closure plate made for a 4” dust collection port.
I cannot attach photos it says the file does not have an allowed extension.
Photos to follow hopefully 🤞
Hopefully the photos are attached.
Thank you!
I certainly enjoy having space to tinker & do woodworking when the urge hits me.
Yesterday I was running oak thru the table saw using power feed and the saw did not disappoint me.
90cummins
   / How does sawdust get into a sealed electric motor? #17
Thank you!
90cummins
That's great news!
   / How does sawdust get into a sealed electric motor? #18
This would be a great science fair project to find out how sawdust gets into a motor,
Good one👍
John Deere GP Tractor (A50514)
John Deere GP...
TEST BID LOT (A50775)
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Toro Workman Cart (A50322)
Toro Workman Cart...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
